Discussing I need a rough figure in the 5.0 Mustangs Forum. I need a rough figure of how much money I'll need to spend. Im ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
03 Cobra
itsChrisTorres is my idol!!!!!!!
I need a rough figure of how much money I'll need to spend. Im in the military and I have a 86' 5.0 back home that my mom's keepin. May sound goofy, but one of my goals is to have that car do a wheel-stand at least a foot tall or more. I know most of the basic things I'll need (alot of horses and torque, really good tranny and clutch, really good suspension setup, ) but I dont know how much money I would have to spend to get the car to do that.
How much $? How many horses would I need? Thanx in advance for any opinions. |
A lot of getting the wheels up has to do with your suspension, so that is a must do
03 Cobra
yeah ive heard that, i always wondered just how important a specific susp. setup is
To get the front tires off the ground the FIRST thing to think about is suspension, and if you do it the right way, you are looking at a LOT of money! Especially if you have somebody else do the work for you...
69 convertible: 302/ DART heads/Z303 cam/Vic Jr./ 650 DP Tremec w/ 4:10s 86 hatch: 302/ Edel Al. heads/ F303 cam/ twin Garret T3 turbos 10 psi intercooled 52# injectors MegaSquirt II EMS http://www.youtube.com/watch?v=_urWMgS_IRQ |
You should have atleast a locker, 31 spline axles atleast I recommend, aftermarket rear control arms, correct springs, rear fully adjustable front struts and rear shocks. Stuff like that. Other things that help are aftermarket K-Members and control arms take quite a bit of weight off the front. Of course a good set of slicks and the know-how to launch at the track.. As far as HP goes that varies. There are 13 second cars that can pull the wheels but you say you want a foot off the ground and even with the right suspension that prob will take a bit more HP. I dont know how much but I would guess it would take at least 350-400hp to get-em up that high.. I could be wrong about that though..
Rotating The Earth 1320 Feet At A Time!! The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, “You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.” |
Asshole™
1990 Mustang LX
9.36@143 mph
Pulling the front tires is easy. Keeping the front tires on the ground gets to be a challenge after a while.
Cheap Mustang wheelie = nitrous kit, slicks, 4.10s, 90/10 struts, good rear control arms and 6000 rpm launch.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
#7 | |
[quote]Cheap Mustang wheelie = nitrous kit, slicks, 4.10s, 90/10 struts, good rear control arms and 6000 rpm launch.
1990 Mustang LX Turbo
9.71@141.6 mph
you would need some suspension work, 4.10 gear ratio some more power to the motor like a supercharger
#9 | |
03 Cobra
#10 | |
03 Cobra
Ill most likely go with a 347 street fighter from Coast High Performance and then bolt on a supercharger or my turbo. I have a garrett turbo that I bought off my best friend, he said he thinks it can push up to 20psi, I might just use that, but I think I would rather run a twin-screw supercharger |
Dude you have the internet look the stuff up you know exactly what you want
03 Cobra
yeah Im gonna do that eventually, I just wanted to get peoples opinions on some figures and I thought this might be an alright topic to talk about
On Probation
i thought it was a good question. As far as money wise though, that is what stangzilla was telling you to use the rest of the internet for. Different companies are going to have different prices. And if you do not have any mechanical skills, installation on most of those parts are going to be a bitch. Gears are over $200 with a rebuild kit, and gear install can be anywhere from $200-400. Slicks =couple hundred. Nitrous = most likely more than $500 plus install. control arms = probably a couple hundred (Not for sure on both upper and lower), struts, not for sure on that either. Good thing is the 6000 RPM launch is free until you break something. But speaking of breaking something, you will want stronger axles too.
+1
thats what I meant. did not mean 2 sound like a dick
03 Cobra
somebody just throw a total number at me please
I know it depends on alot of things, I just wanted to know a simple number lol |
For the stuff I listed above you are lookin at around 2000-2500 give or take.. That of course does not include labor if you cant do it yourself..
On Probation
here is a rough estimate!
$9999999999999999 ( I fixed the number so it wouldnt be so big In all seriousness. probably anywhere from 2-8 grand or more with all the install prices! We can help you out some, but do you really want us telling you every single part and product to put on your car. You could save money by going with other brands and then maybe when you are buying this stuff you might get a good deal. Who knows. Here is what I have right now. A list of all the parts i want or have on my car. At first i put the price and the website i found it at on the paper. Then after i bought each part, I checked that item off the list. You are never going to be satisfied with what you have. you are always going to want more, so your list will grow, and you will have to spend more money on your car. It is too hard to tell how much money, because you can have 11 second cars (more money spent on the car) not pull the wheels, but then you can have 13 second cars (Less money spent on the car) pull the wheels. |
Yeah but you aint pullin the wheels a foot off the ground with a 13 second car thats for sure. Need at least a mid 11 sec car to pull-em that high..
03 Cobra
LOL, Tony u still dont get it........NO I dont wanna know what parts I'll need, where did u get that from, did you read my first post, all I wanted to know was how much money approximately and how many horses, I dont understand y people r tellin me about all these parts that I ALREADY know about, and I think I specifically said that I know all the basic parts I'll need, lol
sorry but I got a lil aggravated with how long it took to get opinions on how much money I may need to spend |
Threads Similar to: I need a rough figure
| cant figure it out | notsoslow50 | 5.0 Mustangs | 7 | July 12th, 2007 10:25 PM |
| go figure! | P.O.S-GT | 5.0 Mustangs | 3 | June 22nd, 2007 11:13 AM |
| Figure this out... | Foxstang90 | 5.0 Mustangs | 3 | February 18th, 2007 01:15 AM |
| Need Help... Cant Figure Out | mustangrebuilder | Classic Mustangs | 5 | September 7th, 2006 12:48 AM |
| cant figure it out | ttop5.0 | 5.0 Mustangs | 2 | August 26th, 2006 07:54 PM |
