Brake issues
Old September 7th, 2009, 02:29 PM   #1
1998 Cobra
13.24@105.66
Brake issues
I am lost trying to fix this problem...
I recently put on a full 5 lug swap. It has 95 gt front spindles and breaks and the rear is a 5 lug conversion axle with drums.
Before the swap, the pedal felt great and stopped well.
After wards, the pedal is super spongey and feels like I only have front brakes.
There is NO air in the lines. I have bled them 10 times now and that is not the problem.
Someone suggested that although I have rear drums that I should switch to an all disc brake proportioning valve.
The guys car I got all the stuff from was identical to mine except he had an all disc prop valve.
What do you think?
weeee foooord!
Old September 7th, 2009, 02:36 PM   #2
12.8@103... stock motor
11.8@113...150 shot
R0B0T can only hope to improve
have you yanked on the e-brake yet?
if not do it a couple times...
also roll backwards and apply the brakes...
Old September 7th, 2009, 03:08 PM   #3
89' LX Conv.
12.8@113
jamilla is on a distinguished road
I've read that a new booster is generally needed.
Old September 7th, 2009, 11:59 PM   #4
The Big Spoon
jessemachone's Avatar
88 5.0 5 Speed Notch <><
never fast enough
jessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of light
How old are your brake lines? The one in the back may be shot. I wouldn't think that you'd need a new valve because you didn't replace or modify any hydraulic parts.
If you didn't mess with the adjusters while you replaced the axles, you shouldn't have an adjustment issue.... unless your 5 lug drums have the wrong inside diameter.
Pumping the e-brake handle won't do anything.
Last edited by jessemachone; September 8th, 2009 at 12:02 AM. Reason: additional info
Old September 8th, 2009, 03:48 AM   #5
mxnate116's Avatar
SVTfocus, F250
mxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the rough
dont you need a larger master cylinder for the larger front calipers?
Old September 8th, 2009, 05:57 AM   #6
The Big Spoon
never fast enough
yeah, if your caliper bores are bigger, you will need a master cyl with a bigger bore. I was thinking that you used the original calipers.
Old September 8th, 2009, 09:59 AM   #7
With using sn95 rear disc brake parts you generally need to switch to a 3-2 port master cylinder and a proportioning valve upgrade or at least modify the stock one.
read here: 3-2 Port master cylinder conversion kits for Fox3 Mustangs (87-93)
and here: Fox Body Mustang MC and PV Upgrades
Old September 14th, 2009, 12:58 PM   #8
1998 Cobra
13.24@105.66
I'm just really confused because I wanted the setup because it had rear drum brakes - I didn't think I needed to change anything else as long as it's disc/drum
weeee foooord!
Old September 15th, 2009, 07:52 PM   #9
1998 Cobra
13.24@105.66
ok so on thur im gutting the stock prop valve and putting an adjustable one on the firewall. Well see how that goes as it's relatively cheap. might as well try it
weeee foooord!
Old September 16th, 2009, 01:20 AM   #10
did you post this up on corral.net? I know your on there just wondering if you did because your question would be exposed to a larger crowd as well
Threads Similar to: Brake issues
brake master cylinder on big brake kit? supercharged03gt 99-04 3 August 14th, 2008 12:40 AM
Alpine IVA-D310 foot brake and e brake switch ?s 97Cobra Audio/Video 2 February 2nd, 2008 07:31 PM
Brake light switch problem after upgrading brake booster black88 5.0 Mustangs 2 January 20th, 2008 11:41 PM
Brake Upgrades/ SN95 Spindles and Cobra Big Brake Kits OcOnnor220 Modular Mustangs 2 July 8th, 2007 12:36 AM
General question on brake system issues (bleeding/no pedal) 95plainjane General Tech 3 July 3rd, 2006 11:22 PM
