#21 |
2001 Mustang SVT Cobra
![]() iTrader: 1 reviews
well, let me see.... U-joints? Slip Yoke? input shaft getting warped, tailshaft bushing, pinion bearings going bad, unbalanced shaft or missing weights. Could be so many things bro.
Mine vibrates between 90-140. Anything before or after is ok. I have a balancing problem. It transfers from the driveshaft and when I put my hand on the shifter it "feels" like it stops, but the underlying problem is still there.
Slow, really slow Cobra. Wanna see?![]() MM Cobra Club Member #81 "TAMPA BAY AREA CREW"
#22 |
1986 ford mustang gt 351w
Ya When I change that fluid Ill get under there and do some checking just gotta find time to do it, how are aluminum drivehafts? And where can I get one online? They worth it?
#23 |
Aluminum are good, light weight. Unless you're doing some serious competition or are into big time track numbers, weight reduction, I wouldn't spend the money.
#24 |
Nope just a 400hp street car for now.
#25 |
Probably gonna order the one at jegs it's a ford racing one looks legit
#26 |
Just drove home from work, this vibration is getting bad it
Starts in 4th at higher Rpms and 5th cruising at about 75, if I let off the gas it gets less as soon as I get back on the gas it starts getting worse? Where to start??? |
#27 |
modded 95 gt vert
I have a shifter shake with my car as well.but when i grab it it also stops??? Cant figure it out?
BLACK ON BLACK 95 GT VERT FULLY CONVERTED TO A 95 COBRA AND MODIFIED WITH ALOT OF GOODIES AND A BB SINGLE T67 TURBO KIT. 526.14RWHP 496.00RWTQ @6PSI. RAN OUT OF FUEL @5500RPM PROJECT CAR AKA MONEY-PIT LOL!... TUNED BY GEORGE @ AKRON HP.
#28 |
1991 Ford Mustang GT
my button on my E brake rattles and makes noise...its so annoying
#29 |
89 Coupe
fast
Ive had the same problem in my old T5's and found that the problem was in the input shaft. Shimmed the input shaft bearing and it went away. I noticed when I took it out that the input shaft itself was kinda wobbly.
427 YSi 1270 hp and streetable!!!
Threads Similar to: shifter shake
| i thought it would shake more than this | Imran | The Clubhouse | 12 | April 7th, 2009 01:02 PM |
| shake | terribleonexx88 | 5.0 Mustangs | 7 | March 29th, 2008 11:13 PM |
| Wheel shake | MustangMatt | 2005 - 2010 | 9 | October 6th, 2007 10:17 AM |
| Ping I cant shake | Juggalo_X | The Clubhouse | 30 | June 22nd, 2007 08:59 PM |
| Overheat and Shake! | TorqueMonster | V6 Mustangs | 4 | August 19th, 2006 08:25 AM |
