pete jackson gear drive
Old February 10th, 2007, 11:29 PM   #1
El Conquistador
whiteboycustom's Avatar
83 coupe
whiteboycustom is just really nicewhiteboycustom is just really nicewhiteboycustom is just really nicewhiteboycustom is just really nice
Send a message via AIM to whiteboycustom Send a message via Yahoo to whiteboycustom
ok so i get teh car back up and running today only to have oil gush out of the motor, further inspection the timing chain gasket is done for, since i have to pull everything off to replace it is a pete jackson gear drive worth having will it make a different or what or just a waste of money, ill be ordering all the gaskets monday so ill be checking back for any onfo from u guys
thanks
Old February 11th, 2007, 12:05 AM   #2
TENGRAM is on a distinguished road
Re: pete jackson gear drive
thanks
overkill? maybe. waste of money? not IMO.
89 GT t5 3.73
www.my5oh.com/
Old February 11th, 2007, 05:02 PM   #3
all motor
SALIV8's Avatar
92 coupe
9.94@136.40
SALIV8 is on a distinguished road
is it stock? if ur pushin respectable hp, i would do it.
Old February 11th, 2007, 10:05 PM   #4
El Conquistador
83 coupe
650 demon,mild cam, l/t bbk headers, x-pipe with 40 series delta flow, msd ignition, electric fan, underdrive pullies on order, im looking to get new twisted wedge heads in the near future even though my brother swears up and down gt40 heads will do just fine, he says he hears to many horror stories about alum heads
http://www.donttearmedown.com/
Old February 11th, 2007, 10:20 PM   #5
Just never let the engine overheat becausee the heads will warp. Other than that, twisted wedges should suit your setup much better.
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old February 11th, 2007, 11:11 PM   #6
Stangzilla's Avatar
Stangzilla is on a distinguished road
The Trick Flow or AFR 165cc heads are way better that the GT40's
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old February 12th, 2007, 05:55 AM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I'd dump the gear drive for a timing chain.
Old February 12th, 2007, 10:07 AM   #8
El Conquistador
83 coupe
thanks guys all i needed to know
Old February 12th, 2007, 10:11 AM   #9
FaStStAnG5-0's Avatar
FaStStAnG5-0 is on a distinguished road
Send a message via AIM to FaStStAnG5-0
i had a gear drive in my truck & every thought it was a blower.. & i just never opened my hood for people! haha!
http://www.cardomain.com/ride/2461223
1994 GT: MSD 6AL, BBK O/R H-Pipe, Dynomax Race Bullet mufflers, 3:73 rear, Hurst Short Shifter, MAC cold air intake & much more coming soon!
Old February 12th, 2007, 11:59 AM   #10
Stangzilla's Avatar
I agree with you but I am wondering why you say that Darrell?
My reason is why spend almost 250 bucks for something you dont need?
Old February 12th, 2007, 12:18 PM   #11
El Conquistador
83 coupe
yea i asked because i didnt know if it would be a improvement or not, if i dont need it then thats 250 that can go to suspension or some other part i need
Old February 12th, 2007, 12:21 PM   #12
Stangzilla's Avatar
It does help the timing be a little bit more accurate but mostly it just makes noise. If you want super accurate timing you can get a normal timing chain and a MSD crank trigger set up for cheaper than the gear drive minus the noise...
Old February 12th, 2007, 12:24 PM   #13
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Gear drives transfer alot of harmonics to the valve train.
Old February 12th, 2007, 12:27 PM   #14
Stangzilla's Avatar
Ok did not know that but it makes sense.. Noise = frequency = harmonics..
Thanx...
Threads Similar to: pete jackson gear drive
sneaky pete Sam'sWildStang V6 Mustangs 4 July 4th, 2007 01:55 PM
Jackson and Al Sharpton WAR-PARTY The Clubhouse 7 May 21st, 2007 12:21 PM
Gear drive? fogged306 5.0 Mustangs 6 April 10th, 2007 06:47 PM
BARRETT JACKSON vichael1 The Clubhouse 5 January 17th, 2007 12:00 AM
7 tooth drive gear or 8 tooth drive gear for my 98 GT manual Blue98GT Modular Mustangs 1 January 6th, 2007 07:27 PM
