Discussing carb to efi in the 5.0 Mustangs Forum. So I see a few threads for going efi to carb but what about the ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
carb to efi
So I see a few threads for going efi to carb but what about the other way around?? Does anyone have a good link for carb to efi?? I'm going for a daily driver and I won't see much track time. Also, I have a 351W if that really makes much of a difference.
1987 Mustang LX
13.9@102.43
Fuel injection atomizes the fuel by forcibly pumping it through a small nozzle under high pressure, but a carburetor relies on the vacuum created by intake air rushing through it to add the fuel to the air stream.
A carburetor performs several important functions in one single component: it measures engine load, calculates the amount of fuel needed, and adds the required fuel to the air stream. With fuel injection, these functions are performed by separate subsystems and components. This means that each subsystem can be specialized and optimized for its particular role, which brings a number of important performance benefits compared to the compromise solution offered by carburetors. http://www.lycoming.textron.com/main...lInjector.html |
Thanks for the information but I need something more along the lines of what parts are going to be needed.
In order to go to EFI, you will need a proper fuel system from tank to injectors, you will need injectors, fuel pressure regulator, 02 sensors, Intake air temp sensor, coolant temp sensor, MAP sensor, or MAF sensor (whichever style EFI you choose to run) you will need a computer to control the EFI, as well as a whole wiring harness to adapt all of the components into the car. You will also need to re-wire most of the car with relay switches to power the computer and EFI components.....it is not a small task. The best way to easily do it is to source all of the components from one donor car..... Or, if you are more daring, you can build your own system like I did on my Twin Turbo car.....which uses a stand alone EMS that is tuned from my laptop.....
69 convertible: 302/ DART heads/Z303 cam/Vic Jr./ 650 DP Tremec w/ 4:10s 86 hatch: 302/ Edel Al. heads/ F303 cam/ twin Garret T3 turbos 10 psi intercooled 52# injectors MegaSquirt II EMS http://www.youtube.com/watch?v=_urWMgS_IRQ |
Well tell ya wat try an find a EFI 5.0 mustang thats been blown up but still has everything on it an just start switching everything over.
#6 | |
1987 Mustang LX
13.9@102.43
i do what 86 said.. the kits are gonna run ya 2-3 grand heres the link any ways http://www.mustangsplus.com/Merchant..._Code=efi_kits |
Threads Similar to: carb to efi
| CARB OR EFI | BLACKNIGHT5.0 | 94-95 | 10 | August 16th, 2007 04:39 PM |
| efi to carb please help | itsmyfiveoh | 5.0 Mustangs | 33 | June 20th, 2007 03:26 PM |
| To carb or not to carb? | MSO | 5.0 Mustangs | 14 | December 9th, 2006 01:33 PM |
| carb ? | terribleonexx88 | 5.0 Mustangs | 11 | December 4th, 2006 02:21 AM |
| V6 EFI vs Carb | quikstang2 | V6 Mustangs | 3 | August 17th, 2006 07:19 PM |
