Look Ma! My First Post!
heads & Cam
What heads and cam would be the best for max horsepower :award
11.47@120.58
What mods have you done already and what's your plans for the car. There really is no best cam, just depends on your combo. I like AFR heads, but the size depeds (once again) on your other mods.
Define max horsepower.
We all hate questions behind another question but it's hard to tell if your not specific. What motor you have and what plans to you have.
THE BEAST IS FOR SALE!!! GTX RACING & PERFORMACE CLUB OF TEXAS Meets and greets, drag racing and good eats, you know you want it. GTX Racing Tony P. 214-257-3635 http://www.moddedmustangs.com/forums...vehicle&CID=43 |
#5 | |
Re: heads & Cam
#6 | ||
Re: heads & Cam
Kiddin'
I have the same question
I have a 93lx with a 5.0 5speed my modds consist of an edelbrock Performer RPM II intake manifold with a 70mm edlelbrock TB. Mac headers, H-pipe, & exhaust. CAI and a PRO 5.0 short throw. I have 373's also I think I want to go w some AFR heads I also plan on going with a Vortech in a year or so and also plan on doing a 331 piston kit What cam and head pack do you guys suggest? And I am guessing that when I do the cam and heads, i will need to get a bigger fuel pump and injectors?? |
AFR, Trick Flow and Canfield are all good. Keep in mind that Trick Flow heads are the only heads with 2.02 intake valves that will clear stock pistons. Any other head you use will need a maximum of a 1.94 intake valve or they will not clear the pistons. AFR heads also have junk valve springs so you will want to change them before you put them on your car or you will have problems down the road.
What cam and cam size should I go with
I changed my mind on the AFR's I think I will go with a set of twisted wedge heads |
#10 | |
#11 | ||
Its a very good "off the shelf" cam
9.91@ 134mph 1/4 - 6.17@ 109mph 1/8th - 1.33 60' - Stock ECU & Stock Suspension......and getting faster . BIVENS RACE CARS FTMFW!!! |
Threads Similar to: heads & Cam
| GT 40 X Heads. Need Help Deciding On These Heads, Or AFR`s | BillR1970 | Parts | 8 | May 12th, 2009 10:01 PM |
| GT40 heads vs GTP heads | 99TurboV6Stang | 5.0 Mustangs | 9 | September 18th, 2007 10:34 PM |
| RHS heads , are they good cylinder heads? | hitorx | 5.0 Mustangs | 25 | May 12th, 2007 10:55 PM |
| 289 Heads | ezra27 | General Tech | 0 | December 31st, 2006 12:09 AM |
| Boss 302 Heads Same As Cleveland Heads? | ken5_0 | Classic Mustangs | 8 | September 25th, 2006 04:18 PM |
