Discussing new here, idle woes in the 5.0 Mustangs Forum. ok thanks will try, but made a bunch of gaskets that restrict flow and increase ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#21 |
ok thanks will try, but made a bunch of gaskets that restrict flow and increase but still had no luck, when you install this do you have to go thru the idle procedure, and rest the tps?
#22 |
nope. this little plate simply bolts in, and adds more air through the IAC when it is idling. it compensates for the mods on your car. No reset or anything else needed. i put mine on, and immediately saw a difference. I tuned it a little and it was amazing how it fixed my idle issues. I will sell you mine if you need me too, but it'd be a few days before i could get it off and send it off. i have mine screwed closed because i am running a speed density system now ( off of my laptop) with no EGR or anything. I just have the screws all the way closed. basically just a blank plate...... I'll switch it out if you need it, I just need to run down to the hardware store to pick up some shorter bolts for it...
69 convertible: 302/ DART heads/Z303 cam/Vic Jr./ 650 DP Tremec w/ 4:10s 86 hatch: 302/ Edel Al. heads/ F303 cam/ twin Garret T3 turbos 10 psi intercooled 52# injectors MegaSquirt II EMS http://www.youtube.com/watch?v=_urWMgS_IRQ |
#23 |
'88 LX body '91 GT D/T
8.7 in the 1/8th
If the IAC and TB plate doesn't work, try out the coolant temp sensor. Sounds like you are in open loop mode. Car always thinks its cold. Will idle hi to compensate for the low temp.
More nice pics on the parts man!! Sweet shots!
Founder of the I don't like my shit centerd and want it back the way it was dammit! club www.myspace.com/evoalliance greatest band alive |
#24 |
it doesnt run high just up and down when i start or come to a stop, wouldnt a code come up if that was the case?, i can pick up a plate at local store no prob
#25 | |
#26 | |
#27 |
8.7 in the 1/8th
I wasn't doubting in the least. Just my thoughts. Went thru that last year w/ my ex's GT and hers surged. Bad sensor. Was in open loop.
#28 |
i increased the size by cutting the middle out of the gsket, in return that increased the airflow, small increaments, made my idle go up but still surged
#29 | |
#30 |
8.7 in the 1/8th
You are my hero of the day!!!!!!! Really. I mean that!!
#31 |
ok thanx guys ill pick up parts tommorow and let you know how she goes, i just cant handle when things dont work like they should, obsessive compulsive when it comes to my car
#32 | |
#33 |
no luck, tyred of spending money, fuck it
#34 |
#35 |
1990 LX hatch
Just set your idle, if you set it too low then the IAC has too much trouble trying to do what the throttle blade does. All too many guys try to set there idle too low for that lobey sound but the computer likes it higher and will try to keep it there using the IAC
#36 |
put her back on the hoist noticed that one of th o2 sensors wasnt threaded in all the way and it had an exsuat leak, cleaned the o2 on both sides and tighten them down myself and whamo, perfect idle when warm anyways, still searches when cold but barely noticable,thanks for your guys input
#37 |
My car did the same damn thing!! All i did to fix the problem is upped the idle a hair. Theres a screw on your throttle body at your throttle linkage try it and it will if your problem. Only turn ir up a little bit you dont want to make your idle to high. I now idle at 950-1000 after it warms up.
Crate 302, Trick Flow Intake R, 75mm MAF, bbk 75mm throttle body, bbk 76mm EGR spacer, 351 Winsor heads ported and polished by Bennet Racing, Lunati cam, 30 pd. Injectors, TKO 500, aluminum drive shaft, bbk mid length headers, bbk off road H pipe, 3:55, |
Threads Similar to: new here, idle woes
| Maf woes... Help a brother out) | turp | Want to Buy | 8 | August 2nd, 2007 08:22 PM |
| CD player woes | 06RedfireGT | 2005+ | 40 | July 10th, 2007 02:34 AM |
| Air Bag woes | GreenFaleen | The Clubhouse | 18 | April 27th, 2007 01:30 AM |
| Contour Woes... | WVSNS& | All Other Vehicles | 7 | April 10th, 2006 04:35 PM |
| Dangit, poker woes... | mdvaldosta | The Clubhouse | 3 | September 4th, 2005 12:26 PM |
