El Conquistador
msd wiring
so on this 83 mustang i bought it has a 6a msd ignition already installed, what i dont like is that the power wire is ran off the battery to a toggle switch, me and my brother tried to find something that wasnt hot with the key off and get hot and stay hot while starting the car, nothing we can find does that everything cuts off while starting, anyone have this problem before??? i plan on ditching the radio and installing the panel with the rocker switchs if i cant find one, thanks for any input
El Conquistador
anyone have any input before i email the techs at msd
El Conquistador
i have the book for the ignition and nothing on the troubleshoot helped i looked there first,
There is a wire coming out of the ignition key switch that is hot when cranking and when the key is forward. I don't know the color but its there. Everyone does it this way. Get your test light out and keep searching. I've also found wires under the hood by the wiper motor harness that will work too.
I think that the fat red wire for the MSD is supposed to be hooked up to the battery.... mine is hooked up that way.... just get rid of the toggle switch if you don't want it.
69 convertible: 302/ DART heads/Z303 cam/Vic Jr./ 650 DP Tremec w/ 4:10s 86 hatch: 302/ Edel Al. heads/ F303 cam/ twin Garret T3 turbos 10 psi intercooled 52# injectors MegaSquirt II EMS http://www.youtube.com/watch?v=_urWMgS_IRQ |
El Conquistador
if i run the red wire to the battery then without that toggle the car wont shut off, i turn the key back but it still runs so i have to flip the toggle to kill the juice to the ignition
There is a thick red and a small red. The thick red goes directly to the battery and the thin read needs power only when the key is turned forward.
El Conquistador
thanks darrell i will look for that tonight after i pull the motor out
Threads Similar to: msd wiring
| Need some wiring help. | 92sspnotchback | 5.0 Mustangs | 1 | August 14th, 2007 09:39 PM |
| wiring help | 95 mustangmiz | Audio/Video | 1 | June 16th, 2007 12:19 PM |
| wiring???? | 95 mustangmiz | Audio/Video | 1 | June 16th, 2007 12:01 PM |
| Sub/Amp Wiring? | Xeremeh | Audio/Video | 0 | December 10th, 2006 03:11 PM |
