STOCK FUEL RAILS
CAN 5.0 STOCK FUEL RAILS SUPPLY 425-450 FORCEFED HORSEPOWER
in my experience yes. ive seen 440 at the wheels using stock rails on a 306 with a s-trim 12psi of boost. mostly stock bottom end besides bolts, gt-40 upper and lowr , and afr 185's on a dynojet.
91 Gt Convertible RNH Perfomance 331 dart stroker w s-trim dart stroker with s-trim, 91 vert
Yes they can.
THANKS
Yeah they can but you are pushin it. I would spend the money and get some high flow rails. Thats just me though..
If I'm not mistaken, I believe from what I've read that the pure bone stock 5.0's were built for 500hp... There 500hp capable more to say
THE BEAST IS FOR SALE!!! GTX RACING & PERFORMACE CLUB OF TEXAS Meets and greets, drag racing and good eats, you know you want it. GTX Racing Tony P. 214-257-3635 http://www.moddedmustangs.com/forums...vehicle&CID=43 |
450-500 is what i was told for the fuel rails and it seems to be going with what everybody else is saying too.
They prob can but I have learned over the years I myself dont like being close to the limits with anything.. Thats just me though..
Mine isn't going to be touched with under 400 HP, but if i decide on a power adder then i definitely will be upgrading.
If you are going to change fuel rails then be prepared to drop another $1000 or so on braided lines, fittings, filter(s), fuel pump and probably a sumped tank or fuel cell.
I've seen many Mustangs with stock fuel rails in the 500 hp area at the wheels with no fuel delivery problems.
No do your research and the bbk fuel rail system I just put on is $180 brand new and the braided fuel lines are around $80. To sump the tank and shit I dont know but I am pushin 3 somethin at the wheels and I got the stock lines with the bbk fuel rail it comes with everything you need too you just have to cut the crossover line to your length you need and I used some soap and 2 clamps to make sure they stay on and I havent had a problem yet I went through this a couple weeks ago.
http://store.summitracing.com/partde...w=1&N=700+150+ http://store.summitracing.com/partde...5&autoview=sku |
It costs alot more than 80 for the lines. I paid 200 for the fittings another 150 for the lines 250 for my inline pump ect ect. you have nothing more than the low budget setup...
#13 | |
I think you missed the point. Replacing the fuel rails is like flushing money down the toilet if you don't replace the restrictive factory lines and fuel system. The stock rails are the least of your concerns in the stock fuel system.
If you are doing a cmplete fuel system. Which is the ONLY reason why you would need to upgrade your rails.... you are looking at 250-300 for pump and filter...
![]() then you are looking at 150 for S/S lines to and from the motor.... another bill for a decent fuel pressure regulator... also you need to think about all of your AN fitting which run at least 8-10 dollars each..... It adds up quick, and not to mention the new injectors which you should have, that would require your new rails. rails also will cost you a bill or so. All in all you're looking at 1K or more for a decent system.... ![]() ![]()
69 convertible: 302/ DART heads/Z303 cam/Vic Jr./ 650 DP Tremec w/ 4:10s 86 hatch: 302/ Edel Al. heads/ F303 cam/ twin Garret T3 turbos 10 psi intercooled 52# injectors MegaSquirt II EMS http://www.youtube.com/watch?v=_urWMgS_IRQ |
'88 LX body '91 GT D/T
8.7 in the 1/8th
My 2 cents: are you plannin on a return style or returnless system? The $ for lines will add up with a return style. and the type of regulator you want to use will also be a factor. ie. a 2 for a non-return or 3 port regualtor that adjust pressure via the return line. Sounds weird, but thats how the operate with EFI.
Founder of the I don't like my shit centerd and want it back the way it was dammit! club www.myspace.com/evoalliance greatest band alive |
#16 | |
8.7 in the 1/8th
Oh they do. Terrible bad.
like darrell said $1000+ for a goot system. aeromotive sells a complete kit for around $1100.
ps dont foget what a pita it is to get the braided line into the fitting... i made good power with stock rails,
#19 | |
O yea and TT86 nice setup!!! |
#20 | |
Threads Similar to: STOCK FUEL RAILS
| Fuel Rails | Euroeater95 | 94-95 | 9 | August 31st, 2007 04:10 PM |
| Holley Fuel Rails | Skullman | General Tech | 3 | September 26th, 2006 02:38 PM |
| Holley Fuel Rails | Skullman | Modular Mustangs | 1 | September 26th, 2006 10:23 AM |
| Help! Fuel Rails | Skullman | General Tech | 0 | September 24th, 2006 09:09 PM |
| fuel rails | 03stanger | General Tech | 0 | June 8th, 2006 08:17 PM |
