CAN I FIT 10.5" WHEELS ON THE BACK???
Old February 13th, 2007, 11:07 PM   #1
Flavian is on a distinguished road
i've got an 86 gt and im looking for a new set of wheels.. i was wondering if i could fit a deep dish 10.5 on the back without narrowing or cutting? thanks
Old February 13th, 2007, 11:25 PM   #2
Racinjason81 is on a distinguished road
I DONT THINK SO 9S ARE ABOUT IT I GOT 17BY9 03 COBRAS ON MY 91 LX
Old February 17th, 2007, 09:43 AM   #3
jtillery is on a distinguished road
The best case scenario would be rolling the fender lips and removing (possibly flipping) the quad shocks. I wouldn't try to run over a 275 rear tire though. a 17x9 would probably fit alot better.
Current Mustangs:
2004 Cobra Convertible
1993 5.0 LX Hatchback
1992 5.0 LX Convertible
Old February 19th, 2007, 04:12 PM   #4
LIKE JTILLERY SAID 275S ARE AS BIG AS YOU CAN GO WITHOUT TUBBING
Old February 19th, 2007, 04:12 PM   #5
Old February 19th, 2007, 06:21 PM   #6
terribleonexx88's Avatar
terribleonexx88 is on a distinguished road
Send a message via AIM to terribleonexx88
fender flares :wink
85 svo. work in progress
Old February 19th, 2007, 08:13 PM   #7
redalert89 is on a distinguished road
take it to a shop install longer studs and get some zero off-set spacers
Old February 19th, 2007, 09:03 PM   #8
86er's Avatar
28x10.5x15 fits on a 5.5 back spacing, unless its different from a 87-93
Just a truck
Old February 27th, 2007, 04:09 PM   #9
Smoken 85 is on a distinguished road
it will fit with a dolly
the 10.5 will fit on the back but you have to roll the lip up tight on the rear fender
Old February 27th, 2007, 07:58 PM   #10
foxstang is on a distinguished road
they fit on my 89 gt
89' 306 W/ Edelbrock performer 5.0 heads, BBK SSI intake, F-303 cam, 75mm MAF, 75mm TB, 30lb injectors, 255lph fuel pump, BBK afpr, BBK shorty headers, Off road X-Pipe, Flowbastards, and 3.73 gears.
Old February 27th, 2007, 09:34 PM   #11
zero is on a distinguished road
Send a message via AIM to zero
so 86-93 17x10.5" rims will fit in there?
92 lx
351W w/ 60 overbore
holley 600cfm carb
weiand stealth dual plane intake
240/246@.510 cam
bbk long tube headders
msd coil
5 lug axle conversion
3.55 gears
mach1 style 17" rims
Old February 27th, 2007, 10:29 PM   #12
1993 Cobra
9cobra3 is on a distinguished road
Send a message via AIM to 9cobra3 Send a message via Yahoo to 9cobra3
Man no problem slide those 10.5" in the back no problem. Unless you get greedy like me and it will be a bit of a headache. But, 18.10.5" 275 !!! :award
Old February 28th, 2007, 02:04 PM   #13
Just remember that with the 10.5 you may need to roll the lip of your fender, It will take more than the baseball bat trick
Threads Similar to: CAN I FIT 10.5" WHEELS ON THE BACK???
4-lug "custom" wheels??? 6T8coupe Classic Mustangs 2 May 2nd, 2007 03:11 PM
Bassani "Racing" series cat back nolife 5.0 Mustangs 3 March 9th, 2007 10:50 PM
