Discussing Car will not run in the 5.0 Mustangs Forum. I fire up the car this morning, starts fine like normal. 3/4s of the ...
Old October 19th, 2009, 07:59 PM   #1
1993 5.ohhhh
14.47 at 96 mph
Car will not run
I fire up the car this morning, starts fine like normal. 3/4s of the way to my destination the car shuts off. So I go to crank it and makes almost the dead battery noise, but one click, then it goes back to cranking. So I keep cranking but open the throttle 100 percent and it cranks. I get on my way to school. I get out of class it fires up idles for 3 seconds then dies. Then makes the battery noise then dies. When the motor starts building compression, the rpms are jumping, and it wants to start is were I notice something funny. Only then will the dash lights come on: ebrake, airbag, battery, check engine. If the cars off but key in auxillary nothing shows up on the dash. Radios and lights all work though. What do you think it is?
exploder top end with 12 psi of v-tech
Old October 19th, 2009, 10:24 PM   #2
flyin ryan's Avatar
I don't know only time i've had that type of issue was a screwed ground but I can't honestly say that would be your total issue.
91 gmc syclone - not stock, money maker
90 lx - turbo, bolts ons etc
88 lx hatch - tons of bolt ons and daily driven
02 zx12r - dyno'd 197 to the wheel
http://i44.tinypic.com/2qlws5c.jpg
Old October 20th, 2009, 01:00 AM   #3
1993 5.ohhhh
14.47 at 96 mph
The ground strap from the firewall to the back of the passenger heads' bolt was loose. I didn't have wrench to tighten it. My buddy jiggled it before I got it towed while I tried to start it and nothing, maybe it has to be tightened down all the way.
Old October 20th, 2009, 11:03 AM   #4
1993 5.ohhhh
14.47 at 96 mph
Well I tightened the ground on the head. It starts much smoother, but still it kills itself after 3 or so seconds idling. I am also still not getting anything on the dash with the key in the on position unless the car is running.
Old October 20th, 2009, 11:25 AM   #5
Vanilla Godzilla
93hatch's Avatar
1988 Japanese girl
The sound of fap
test the amps the alts putting out cuh, have you tried jumping it?
Originally Posted by 2010stang View Post
93 hatch your just pissed cuz my v6 will fuck your shit up thats sad fuck you fag
Old October 20th, 2009, 11:29 AM   #6
1993 5.ohhhh
14.47 at 96 mph
Electrical is NOT my thing. Im guessing I could just use a dmm to test the amps? and were would I do it. Do you mean jumping it with another car? If so I didnt think about it since everything works but the dash... minus the fact this it wont stay running. Ill try it now though.
Old October 20th, 2009, 11:32 AM   #7
Vanilla Godzilla
93hatch's Avatar
1988 Japanese girl
The sound of fap
electrical is def gay dude, idk what a dmm is but it sounds sexy, and jumping it with another car and just leave the cables on and see if it says running that way, or once you get yours started pull the neg cable off the battery and see if it dies
Old October 20th, 2009, 11:34 AM   #8
flyin ryan's Avatar
If you don't get any dumby lights doesn't that normally point towards a fried ecm? or an issue with the ecm's ground?
Old October 20th, 2009, 11:34 AM   #9
1993 5.ohhhh
14.47 at 96 mph
lol it's just that tool with the red and black needles for checking power. I went to jump the car with my brothers v6, and his battery is dead. I've been having quite the horrible two days haha.
Old October 20th, 2009, 11:36 AM   #10
1993 5.ohhhh
14.47 at 96 mph
Idk, to be honest. Never had any electrical issues so I've never read into any threads like that. Everything else works fine: radio, headlights, blinkers, hazards, domelight. As soon as it starts everything is 100 percent even on the dash until it dies.
Old October 20th, 2009, 02:12 PM   #11
1993 5.ohhhh
14.47 at 96 mph
Ok well I was just playing with the car. Pulled my chip, same bs. I did put the key in the aux position, and if I turned it just a nut hair, but not enough to start the dummy lights come on.
Idk if it's relevant, but my electric fan is wired into the msd, so when ever I turn the key in the on position it kicks on. Could it have anything to do with my blaster coil?
Old October 20th, 2009, 06:20 PM   #12
1993 5.ohhhh
14.47 at 96 mph
swapped in an a9l, no luck still.
Old October 20th, 2009, 09:39 PM   #13
Lind's Avatar
1994 Ford Mustang GT
check your alt? fuel pressure?
not really sure lol
My Daily Driver
Old October 20th, 2009, 10:12 PM   #14
1993 5.ohhhh
14.47 at 96 mph
it was the starter switch under the steering wheel. $ 11 fix; however, now my battery is dieing, it dies off fast to. Battery light is on the dash.
Old October 20th, 2009, 11:55 PM   #15
Chris951's Avatar
1988 T-top 5.0
I was about to say starter switch then I read this post lol..
1988 LX T-top 5.0:
70mm BBK Throttle Body
4.10 gears
BBK shorties, Pypes O/R X-pipe, Dumped Flowpaths
Pro 5.0 shifter
Old October 21st, 2009, 12:21 AM   #16
1993 5.ohhhh
14.47 at 96 mph
I had friends who have been in the game far longer then me make the call, and they were right.
Threads Similar to: Car will not run
run your car on water graystang01 The Clubhouse 1 June 27th, 2008 10:01 PM
car wont run gyellow 5.0 Mustangs 6 May 30th, 2008 09:46 PM
Run your car on water! 03_StangGuy The Clubhouse 19 May 27th, 2008 03:43 PM
What Will My Car Run? 1990mustanggt 5.0 Mustangs 15 July 26th, 2007 10:27 PM
Does any one run these on their car....? Kingcater 5.0 Mustangs 27 January 18th, 2007 01:04 AM
