1984 Mustang GT
help with 351 heads
hey guys i have an 84 302 that i got 351 heads for the heads are the same year as the motor what do i need to do to put them into the car?
!FACEPLATED!
get bushings i believe since the bolts holes in a 351 head are bigger than the ones in the 302. not sure what else
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ |
Proud American
That should be the only thing...
!FACEPLATED!
1984 Mustang GT
couldnt i just use the same bolts for the 302 heads on the 351 heads... and would the intake off the 302 fit the 351 heads correctly?
!FACEPLATED!
yes the intake will fit just fine. You can use the bolts from the 302 just get the bushings for them
1984 Mustang GT
ok the 351 head bolts wont fit the 302 block
!FACEPLATED!
not they are too big. 351 head bolts I believe are 1/2" and the 302 are 7/16" if i remember correctly
1984 Mustang GT
you know if i have to time it differently of not
!FACEPLATED!
time it according to the cam specs. You should be fine. I have a set of 302 heads on my 351.
1984 Mustang GT
why smaller heaDS ON a bigger block? what difference will the 351 heads do to the motor
!FACEPLATED!
I did it because it was a budget build and There was only 2k miles on them
1984 Mustang GT
what will the 351 heads do to my motor?
1984 Mustang GT
how do these bushings go on by the way...
!FACEPLATED!
the go into the hole the put the bolt through. they keep the head from moving because of the larger hole ones the head is installed
1988 Mustang LX Coupe
N/A
351W heads and 302 head are exactly the same thing EXACTLY! the 1 and only thing different is the bolt size you have to have bushings to put 351W heads on a 302 and you have to drill out 302 heads for a 351 how do you not understand this?
-Joe Alvarez |
!FACEPLATED!
most are. some of the early early 351 heads had different size valves. I will have to wait till i get home to know exactly what years but they are rare now-a-days
1984 Mustang GT
so there wont be a power difference
Threads Similar to: help with 351 heads
| 351 heads etc. | 95wip | 5.0 Mustangs | 3 | March 20th, 2008 12:22 PM |
| 351 W or C heads | CR70fastback | Classic Mustangs | 7 | April 29th, 2007 06:10 PM |
| 351 heads? | gregkelley | 5.0 Mustangs | 11 | April 16th, 2007 02:21 PM |
| 351 w Heads | 92mustanglx | 5.0 Mustangs | 11 | January 24th, 2007 09:21 PM |
| 351 Heads | 03stanger | 5.0 Mustangs | 10 | November 1st, 2006 08:58 PM |
