#21 |
1991 mustang 5.0
If you look on the part of the pipe where it contacts the head, there are 2 bolts that hold the pipe down and then there are 2 bigger holes. The two bigger ones are threaded and need to be plugged if the pipe is off. I stuck some fat bolts in mine a few days ago with no problems
#22 |
oo i didnt think the bigger ones were threaded...thats where the air comes out right
#23 |
1991 mustang 5.0
#24 |
All I did with mine was to hacksaw off the air tube that enters the block on the back of the head, remove the block, put high heat silicone on it (flat side), turn it around so flat side and silicone are against head/air port and install the bolt that was holding it to the head. Simple and after 4 years not a leak.
#25 | |
1991 mustang 5.0
#26 |
yea bolt idea sounds better...should i get some of that tape stuff
#27 |
1991 mustang 5.0
Just buy bolts and stick them in. That's what I did and it's fine now. The size is on the first page of this thread.
#28 |
thank you
Threads Similar to: smog delete
| Smog and AC delete. | INSTALLER020 | 5.0 Mustangs | 30 | October 23rd, 2009 08:38 PM |
| Smog delete | Timm10221 | 5.0 Mustangs | 0 | April 22nd, 2008 09:06 AM |
| smog and ac delete... | e3sean | 5.0 Mustangs | 7 | March 1st, 2008 02:31 PM |
| AC Delete and Smog Pump Delete | triplethreatt77 | 5.0 Mustangs | 14 | December 24th, 2007 07:09 AM |
| Smog Delete? | 95blackbeauty | 94-95 | 8 | December 20th, 2007 03:44 AM |
