1987 Mustang GT
Help Leaking Coolant
Today while removing my sway bar I noticed some liquid under the car. it wasnt oil come to fid out its coolant. I shined a blue light towards the water pump (Blue LED's make Coolant Glow green) I can see coolant coming out from the water pump seal. Not a whole lot just a small amount.
Now my question is should i replace the entire water pump or do you thing it is just the seal that has gone bad? |
1988 GT
how many miles are on the pump? if you have the cash it might be a good time for a new pump and gasket.
Also, check the thermostat housing just to be sure the coolant is flowing down from somewhere above rather than where you see it.
![]() Last edited by 88-gt-t-top; October 31st, 2009 at 03:23 PM. |
1987 Mustang GT
I have have no clue how many miles Just recently bought it engine has been rebuilt but dont know about the water pump doubt he replaced that. I just figured id find out if i could just replace the gasket. But pumps are not that expensive so i guess i could go that route.
1987 Mustang GT
Also about the thermostat housing i did see some coolant up around the hose leading to the heater core just above the water pump i checked it the clamp is tight so i dont know if coolant can still leak threw or what probaly be better off just replacing all the hoses, water pump gasket and thermostat gasket?
1988 Mustang 5.0 LX
12.48@118.27
Its best to change the waterpump along with the gaskets but if your lucky you won't have a bolt that is stuck and you have to bust the timing cover to get it out so you would have to replace that to and you have to get a new timing cover gasket. I had to do that and it was a pain in the ass but I still had to replace the timing cover.
1988 GT
You can buy just this one or they sell a bunch of gaskets in a set depending on what you're replacing.
![]() Summit Racing Part Number FEL-35211 |
1988 Mustang 5.0 LX
12.48@118.27
go to an auto part store and snag one for 2 bucks
id say if you dont know the miles on the water pump. better be safe than sorry. since the water pumps off. spend the extra 30-40 bucks and throw a water pump on there. you dont wanta just put a gasket on there than 1 week later the bearings start to go and or start weeping out the weep hole. than that new gasket was a waste.. thats my 2 cents..
1994 mustang gt
10.82 sec
i would take a second look,i thought i was leaking coolant from my water pump but when i looked again a little closer,i found out it was coming from thermostat housing
seans mustang
1987 Mustang GT
well i bought all new gaskets hoses thermostat and water pump. only thing is the guy before me installed an aluminum radiator. I cant find the drain valve to drain the system. what is another way to drain it?
Remove to lower radiator hose and drain into a pan.
1987 Mustang GT
Yea thats what i ended up doing got it all back together and no more leaks. YAY!! Thank for the advice.
1988 Mustang 5.0 LX
12.48@118.27
1988 GT
a little late, but good to hear
Threads Similar to: Help Leaking Coolant
| leaking coolant mystery | ddarkslayer | 5.0 Mustangs | 11 | September 25th, 2009 01:12 PM |
| Leaking Coolant | saltydog_NM | 5.0 Mustangs | 4 | September 30th, 2008 08:38 PM |
| HELP!!! Coolant leaking out exhaust.... | lwhitetrash88l | V6 Mustangs | 23 | April 6th, 2007 03:40 PM |
| coolant leaking here i think. | YNOT | 5.0 Mustangs | 20 | March 22nd, 2007 11:18 PM |
| Leaking Coolant From Where tranmission meets Block | garyvang | 5.0 Mustangs | 0 | April 25th, 2006 06:00 PM |
