idle surge, runs rich and cam noise
Old November 3rd, 2009, 12:44 AM   #1
88notchback is on a distinguished road
i just got a 1988 notch back! this is what the guy that sold it to me said!
midly built 302 erson cam 512 lift, ported e7 heads, dual valve springs. electric fan. tubular k member with tubular a arms, coilovers on the front with 90/10 drag struts. the rear end is fully built and has the axel tubes welded. 31 spline axels 4:10 gear with a eaton posi. extended wheel studs also. drag springs in the rear with 50/50 drag shocks. also has bbk upper and lower control arms. trans is a fully built t-5(5 speed stick)with a brand new clutch installed on saturday, pro ripper short throw shifter, has an aluminum drive shaft. 8pt cromoly cage, mini starter, aluminum radiator. newer mickey thompson drag radials out back, skinny tires up front. interior is mostly stock except for the 8pt cage, the racing harnesses and the monster tach. has a 2 5/8 oil and fuel pressure gauge on the cowl. mallory ignition box and optima in the trunk! now my quistion are the cam seems to be make quite a bit of noise and when the car cold it has idle surges and runs really rich does any one know where i should start to figure out all my problems?
Old November 3rd, 2009, 12:51 AM   #2
laztug's Avatar
1993 Mustang GT
laztug is on a distinguished road
TPS/IAC sensor.
Disconnect them to see if the problem persists.
Stock 5.0 Motor M/T Drag Radials
E.T.- 13.859
MPH-97.23
60 foot-1.853
Old November 3rd, 2009, 01:09 AM   #3
it has a after market intake, intake manifold and throttle body but everything seem to be hooked up! i dont know if that makes a difference, but i am going to go out there and try that tomorrow
Old November 3rd, 2009, 01:35 AM   #4
qwik48r's Avatar
alotta shit
no fat girls fast
qwik48r is a jewel in the roughqwik48r is a jewel in the roughqwik48r is a jewel in the rough
Send a message via AIM to qwik48r
doesnt sound like a crazy motor... I agree with ^^
uhhh... dual springs are noisy.. especially when they are COLD, get used to that.. you say its running rich.. thats about a 1/4 of the story.. when is it running rich? that cam has some decent overlap, I expect it to run rich at idle on a stock computer... Erson does make a great cam, I currently run s .655" solid in a dart topped sbc bracket el dog... serious stick
surging is probably due to not enough timing in the lower RPMs, larger cams usually dont like to run a load at stoplight stop and go rpms...
if i was tuning this car, I would add more timing at idle, and dial back the fuel till its reading around 15.1-7 AFR at idle
mind your business what i drive... i'm on a fucking mustang forum.
qwik's build
Old November 3rd, 2009, 01:50 AM   #5
thanks i will do that tomorrow after work and will let you know!
Old November 3rd, 2009, 02:03 AM   #6
You know those old squeaky springs.....
PeteAndersonRacing.com
Old November 3rd, 2009, 02:41 AM   #7
qwik48r's Avatar
alotta shit
no fat girls fast
leave our relationship out of this...
call me.
qwik's build
Old November 15th, 2009, 08:15 PM   #8
i finaly got to pulling the check engine codes and i come up with
23, 31, 67, 81, 85, now my quiestion is where should i start and could any of these codes cause my idle surge problem? and another question i have is the owner told me these 19lbs injector are good up 450 hp and when i look on the internet it told me there on good up to 265hp what size injector do you think i should put it with the modds i have?
Threads Similar to: idle surge, runs rich and cam noise
Mustang idle surge and base idle reset 1slo5.0 5.0 Mustangs 47 July 26th, 2011 11:52 PM
help idle surge! bambam88 General Tech 1 July 9th, 2007 03:58 AM
Idle surge izze01 5.0 Mustangs 1 July 1st, 2007 02:32 AM
help idle surge! bambam88 General Tech 1 April 11th, 2007 12:26 AM
idle surge slow98gt 96-98 8 February 12th, 2007 04:56 PM
