EEC IV problems
Old February 18th, 2007, 04:07 PM   #1
tekt is on a distinguished road
EEC IV problems
I have an 89' notchback 5.0, 5 speed that has the dreaded CEL. I bought a code scanner, but can't get it to connect to the eec. When I grounded the single wire, the computer wouldn't start the self diagnostic mode. Is the eec fried?
Old February 18th, 2007, 06:16 PM   #2
cobraetti's Avatar
2001 svt cobra
no way (IRS)
cobraetti is on a distinguished road
I think you could try the self-test with a digital voltmeter and see if that works?
Build #1249
MM New Edge Crew Member# 6
Old February 18th, 2007, 08:00 PM   #3
JBIGBOOTSY's Avatar
1990 LX hatch
plug it in, with the engine off. then start the car. With the car running, switch the scanner on to test, you should hear a quick blip in the engine, then it should climb to 2000k and stay there. If for some reason it can't raise the idle, it will abort the test. Mabe try and check your IAC
Old February 19th, 2007, 02:00 AM   #4
The eec won't go into the self diagnostic mode at all. If the scanner is plugged into the port, still no connection to the eec, and the car stops running a few seconds later.
Threads Similar to: EEC IV problems
2.3L Problems. akatagyourit 2.3 Mustangs 51 June 25th, 2007 04:39 PM
problems plz help cams-shelbycobra07 2005 - 2010 6 June 14th, 2007 12:27 AM
more problems ks_emt 2.3 Mustangs 7 June 7th, 2007 04:16 PM
88 GT With A Few Problems Iceman1989 General Tech 3 November 14th, 2006 01:58 AM
Help Please (Car Problems) 98mustang98 V6 Mustangs 1 October 25th, 2006 11:49 PM
