1988 5.0 wont start when warm and sits for a few minutes
Old February 19th, 2007, 12:36 AM   #1
hoserc1 is on a distinguished road
I have a 1988 mustang gt 5.0 atomatic, and if you drive then shut it of for 10 min to 30 it tries to start but does some light pops and revs and then dies after a short while and 6 or more tries you can usually force it to start. Today it did it while and it would not start and the exhaust where it bolts to the manifold got red hot. It looks like there is a cat right there?.
What might cause this and what to do to fix it?
Thanks
Old February 19th, 2007, 01:03 PM   #2
GTXRacing is on a distinguished road
Check your timing...
What kind of setup you have?
THE BEAST IS FOR SALE!!!
GTX RACING & PERFORMACE CLUB OF TEXAS
Meets and greets, drag racing and good eats, you know you want it.
GTX Racing
Tony P.
214-257-3635
http://www.moddedmustangs.com/forums...vehicle&CID=43
Old February 19th, 2007, 06:21 PM   #3
all motor
SALIV8's Avatar
92 coupe
9.94@136.40
SALIV8 is on a distinguished road
check ur egr valve. might be bad
Old February 19th, 2007, 10:21 PM   #4
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
Do you still have the stock H pipe? Might be a clogged cat.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old February 21st, 2007, 02:03 AM   #5
Stock setup. I will check timming.
Thanks
Old February 21st, 2007, 02:05 AM   #6
I will also check egr.
Old February 21st, 2007, 02:07 AM   #7
I do not have the stock h pipe but the are the 2 cats that come almost directly off the manifolds.
I have had 3 people I know say it sounds like the cats are clogged.
So Iam goimg to take them off and hollow them out and put them back on and see what happens then.
thanks
Old February 21st, 2007, 02:16 AM   #8
mikebert is on a distinguished road
Send a message via AIM to mikebert Send a message via MSN to mikebert
If you have a stock setup, before you destroy your cats, it may be worth unbolting your headers at the collector and trying to crank it up with open headers. If it cranks up and runs fine like that, I would think your problem is somewhere past the collector.
Just my thoughts on a little more diagnosis. . .
Old February 21st, 2007, 11:26 AM   #9
mikebert is right, but if you don't want to spend the extra energy and time, check the codes. If no code, replace your cats anyway. Get some high flow cats from the summit catalog.
GTX Racing
Tony P.
214-257-3635
Old February 22nd, 2007, 08:02 PM   #10
I already did the cats and it ran great but died once of ter driving 7 or 8 miles, and restarted on test drive and then went a couple more miles and died after starting from a stop. I went to restart it and it let out very loud back fire. I waited about a minute then got it to restart ran a little rough for about 4 blocks and then ran fine all the way home about 5 or 6miles. I let it sit for about 5 or a little more minutes and it restarted an ran great when before it would not start for an hour or more.
So I do not know if it is fixed or if there is another problem or maybe the same problem still is there. I will drive it some more and see and then post findings.
thanks guys!
Old February 22nd, 2007, 08:55 PM   #11
83 5.0's Avatar
83 5.0 is on a distinguished road
Fuel Pump or Filter? Does pump sound normal when running?
Old February 22nd, 2007, 09:04 PM   #12
JBIGBOOTSY's Avatar
1990 LX hatch
+1
Old February 22nd, 2007, 09:47 PM   #13
It is the same problem it almost starts and revs for an instant and pops and backfires loud, leaves a little black on the ground and has been sitting for 45min since last ran a while since ran last
Old February 22nd, 2007, 10:59 PM   #14
saleenxxx's Avatar
saleenxxx is on a distinguished road
Send a message via MSN to saleenxxx Send a message via Yahoo to saleenxxx
I had the same problem with my 87 GT, believe it or not after a few hundred bucks and lots of running around in circles I found it to be the most simplest thing, The TFI module and pill on the distriburator. I believed I got this at Autozone for 80.00 and replaced the cap and rotor as well. You do have to remove the distriburator to access the side mounting screws on the TFI, will not come off if you dont take it off.My problem was that the car would run great, quick starts, and after running it for more than45 minutes straight it would cut off. It would start about 30-45 minutes later. You might want to try this, also they mentioned clogged cats in this forum, If the cats were clogged this problem would be constant not just after 10 or 15 minutes of not running or running. Its like sticking a potato up the exhaust of a car and trying to fire it!
Old February 24th, 2007, 02:08 AM   #15
I replaced the module in the distributor today. So far my test drives have been good.
Old February 24th, 2007, 12:22 PM   #16
JBIGBOOTSY's Avatar
1990 LX hatch
Oh yea, I a few years ago I owned an 88 gt for like tw0 weeks, and the some thing, replaces the TFI and it was fine.
Old February 26th, 2007, 01:25 AM   #17
I drive the car for a couple of long trips to day with some short stops.
Still is running and driving great.
Thanks
Everyone for the help!
Old February 26th, 2007, 04:08 PM   #18
SVTCobrastang00 is on a distinguished road
I don't know if this will help, but I had a 89 GT that used to die after it was runnig for a while in hot weather, I never knew what it was , until after I sold it, I was told it was some module in the motor, (or near it) that was bad and it caused the car to shut off when it got hot, I wish I knew what the name of the module was, I did years ago but thats not helping you now, sorry maybe someone here knows what I mean.
Mustangs I've owned... but never an SVT it's just my SN here...
'88 5.0 LX 5 Speed
'89 5.0 GT 5 Speed
'87 4CYL Auto
'95 5.0 GT AOD Vert. all else were hard tops.
Threads Similar to: 1988 5.0 wont start when warm and sits for a few minutes
car wont start Bhblondguy 2005 - 2010 24 August 17th, 2007 12:18 AM
Wont Hold Idle When Warm zero 5.0 Mustangs 22 March 16th, 2007 11:39 PM
Car Wont Start? 87ttopstang 5.0 Mustangs 4 February 7th, 2007 09:45 AM
need help...car wont start orlyr21 V6 Mustangs 8 January 13th, 2007 08:17 PM
Stang wont stay running, after warm up...???? ttop5.0 5.0 Mustangs 2 November 28th, 2006 04:10 PM
