swapped my fuel pump with a 255 lph
Old November 19th, 2009, 10:51 PM   #1
1988 Mustang 5.0 LX
12.48@118.27
ddarkslayer is on a distinguished road
So far that fixed my Idle issue but I have another issue. When ever I start my motor the MIL turns on immediatly. I have a stock Fuel pressure regulator. do I have to change that to an ajustable FPR. I have a feeling in my gut that the motor's running rich.
Old November 19th, 2009, 11:51 PM   #2
1988 Mustang 5.0 LX
12.48@118.27
anyone I could really use the help
Old November 20th, 2009, 12:22 AM   #3
1992 Lx
11.39@119.24
stocker works fine with the 255, ran it on my fox
Old November 20th, 2009, 12:32 AM   #4
1988 Mustang 5.0 LX
12.48@118.27
I hit it full throttle and my headers where smoking
Old November 20th, 2009, 12:40 AM   #5
1992 Lx
11.39@119.24
sounds like a timing issue to me dude, go check it with a timing light
Old November 20th, 2009, 02:56 AM   #6
1989 Mustang LX 5.0
sniperd is on a distinguished road
Yeah, Definitely not the FPR, Stocker works fine w/ a 255
Old November 20th, 2009, 10:08 AM   #7
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
Sure, assuming the stock fpr isn't broken. Get a guage on the rail to make sure.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old November 20th, 2009, 10:19 AM   #8
stock fpr should be fine with the pump.. pull the vac line to the regulator and check to make sure there's no gas in the line. If there is then the diagram in the regular is bad and leaking which means you need to replace it but like mentioned above get a gauge on the rail and see what your pressure actually is
Old November 20th, 2009, 12:46 PM   #9
1988 Mustang 5.0 LX
12.48@118.27
I never ajusted my timing ever It was running find with the timing. but does a fuelpump change require a timing
Old November 20th, 2009, 12:47 PM   #10
1988 Mustang 5.0 LX
12.48@118.27
nope the vac is dry
Old November 20th, 2009, 01:03 PM   #11
JBIGBOOTSY's Avatar
1990 LX hatch
Retarded timing will cause high xhaust temps
Old November 20th, 2009, 01:22 PM   #12
1988 Mustang 5.0 LX
12.48@118.27
I have a feeling the timing is advanced but I can relook that
Threads Similar to: swapped my fuel pump with a 255 lph
Boost-A-Pump or GT500 Fuel Pump? stanglifemike 2005 - 2010 64 September 21st, 2009 01:17 PM
Fuel pump question. Stock GT pump to GT (supercar) pump. Nate's4.6 99-04 15 May 14th, 2008 02:25 PM
255 fuel pump on stock injectors *5.0_ponyboy* 5.0 Mustangs 2 April 18th, 2008 06:15 AM
Suggestions on Fuel Cell's & Fuel Pump bstang 2.3 Mustangs 5 January 21st, 2008 09:04 AM
Can oil pump shaft be swapped from the top?? noyz25 5.0 Mustangs 2 July 28th, 2007 11:30 PM
