Clutch fan or electric fan
Old November 22nd, 2009, 01:03 AM   #1
91 fox's Avatar
1991 mustang 5.0 LX
N/A
91 fox is on a distinguished road
I'm on a budget build can i run a s/c with a clutch fan or will u have to convert?
Old November 22nd, 2009, 01:54 AM   #2
1998 Cobra
13.24@105.66
I would for extra room....
weeee foooord!
Old November 22nd, 2009, 01:56 AM   #3
1992 LX 5.0
Devine is on a distinguished road
depends on the s/c setup
procharger provides a bracket to attach the stock fan to their pulley
Old November 22nd, 2009, 02:29 AM   #4
96_5.0_Mustang's Avatar
96_5.0_Mustang is on a distinguished road
electrics better! it will be worth it to covert.
"A large cam will do nothing for you if you can't use it. If you do your combo correctly, you can have both the lope and power.Think of it this way, buying a pack of magnum condoms may be impressive, but whats the point if you can't use them?"
Old November 22nd, 2009, 02:46 AM   #5
mousaleeni is on a distinguished road
+1 for electric. Less drag on the motor.
Old November 22nd, 2009, 11:21 AM   #6
nolife's Avatar
91GT, 88GT, 02GT
I'm still using the factory clutch and fan with my SC'd setup. It works fine and has for years, even with the A/C going.
Old November 22nd, 2009, 01:41 PM   #7
it may work fine but they went to electric from factory for a reason. convert to electric reduce the drag on ur motor.
Old November 22nd, 2009, 05:35 PM   #8
1990 gt
v8muscle is on a distinguished road
electric, love my engine bay clean and open
Old November 22nd, 2009, 07:51 PM   #9
CammedMysticCobra's Avatar
Mustang MystiqueCobra2004
CammedMysticCobra can only hope to improve
Send a message via AIM to CammedMysticCobra
Electic is deflty the way to go
Full bolt ons Fully built Teksid Block Custom Comp Stage 10s missing JLT, Acufab TB and 2.8 Kenne
http://www.youtube.com/user/MysticCobra04
Sold not lost and will never be forgotten.
Old November 22nd, 2009, 08:01 PM   #10
91 fox's Avatar
1991 mustang 5.0 LX
N/A
Ok if i go with a electric what is a good kit?
Old November 22nd, 2009, 08:38 PM   #11
1992 LX 5.0
i would buy the electric fan after you've decided what supercharger you're going with, and what pulley you'll use
if not, you might end up buying twice
Old November 22nd, 2009, 09:18 PM   #12
91 fox's Avatar
1991 mustang 5.0 LX
N/A
looking at a vortech sq-trim run 10psi
Old November 23rd, 2009, 12:04 PM   #13
Atomized
gotn20's Avatar
gotn20 will become famous soon enough
if your on a tight budget just run a taraus fan. That's what i'm rocking for now. It moves more air than my buddys aftermarket fan set up
spray and pray
Old November 23rd, 2009, 01:23 PM   #14
i would recomend a dual fan set up. two smaller fans are better than one big one u will flow more cfm idf u do two
Old November 23rd, 2009, 01:54 PM   #15
nolife's Avatar
91GT, 88GT, 02GT
I know tons of people run the Taurus fan. Here's an opposing opinion to that fan. That fan is not efficient at all. It draws a TON of power, I've seen some numbers as high as 30amps while its running. The older the windings get, the more power it draws. You will need the right wiring and relays capable of handling that power. You will also need some type of temperature controller unless you want to control it manually or just let it run all of the time. If you are still using the factory alternator, it will be overwhelmed. Sure, it will work but the factory 2G alternator is barely able to support the car without an electric fan (the 2G only puts out barely 30 amps at 2500 rpm). By the time you adapt the fan to work, get the correct wiring and a temp controller with or without a soft start, you have spent a decent clip of money and time on a fan that draws a lot of power and an alternator that is running beyond its expected capacity.
Short story, it will work and does work and a lot of people use them but don't make your decision using only the low cost and good availability of the Taurus fan.
Old November 23rd, 2009, 02:31 PM   #16
I agree, I'd bolt the blower kit on first then measure to see how much room you have from the crank pulley and brackatry to ensure you know how much room to play with.
Electric fans have there positives over mechanicals no doubt but like mentioned above, Kits are expensive unless you go the junkyard route which is fine but these fans pull allot of amperage. The taurus fan flows 3300 cfm while the lincoln fan does 4k cfm. Either one is enough to cool a blown or turbo motor but they pull allot of amps and require you to upgrade your alternator (which you should anyways) and you'll have to go with a controller that's rated to handle those high amps or a soft touch type so that's another cost. You have to use 10gauge wiring and possibly a few relays depending on your setup. There's a ton of different ways you can do this and depends on money and use of the car.
I personally have efans in everything I drive so im not trying to sway you one way or the other just trying to help.
Old November 23rd, 2009, 04:48 PM   #17
Atomized
gotn20's Avatar
i agree on all of this man. My car had a 3g alt when i bought it. temp contoller with relay's are cheap as shit. I used my autozone rewards credits to buy mine. I have a friend that has taraus fan with a stock alt for like 4 years with no issues. The power draw is huge but it's just a trade off. I'm gunna be going the show and go route soon so i'm gunna ditch it but it's been a great fan for me. And i live in blazing hot albuquerque
spray and pray
Old November 23rd, 2009, 05:33 PM   #18
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
12" S-BLADE ELECTRIC FAN 1200CFM REVERSIBLE:eBay Motors (item 160379066776 end time Nov-24-09 07:20:29 PST)
hows this for cheap...buy two of em....i have had 1 12 inch on my yota for a few years now and the only time it has overheated at all was muddin and accidently left the ac on
1990 GT
Pro 5.0, 3.73s, TFS Intake, Flows
2004 Impala SS
Supercharged(stock), DD
2001 Tacoma
2.5" Lift, K&N cai, TB Spacer, Magnaflow, Elec. Fan, Stereo MODS!!
Originally Posted by JBIGBOOTSY View Post
my table spoon engine is bigger than the tea spoon engine!
Old November 23rd, 2009, 11:38 PM   #19
I wouldn't suggest that efan to someone with a blower because 1200cfm isn't going to do shit for cooling.
I had a fan out of a astro van that flowed 1400cfm for about four years on my gt until I put the novi2k on. Would over heat withing ten minutes of driving and had to swap in a taurus
Old November 24th, 2009, 01:50 AM   #20
91 fox's Avatar
1991 mustang 5.0 LX
N/A
What about the Black Magic kit??
Threads Similar to: Clutch fan or electric fan
Electric fan hopper 5.0 Mustangs 26 January 19th, 2009 01:18 PM
Electric Fan BLUE91GT 5.0 Mustangs 9 January 12th, 2009 12:45 PM
electric fan hmotes 5.0 Mustangs 5 January 14th, 2007 07:23 PM
electric fan vs fan clutch hmotes 5.0 Mustangs 8 December 19th, 2006 02:03 AM
Electric fan or Flex fan? vivoronte 5.0 Mustangs 20 February 10th, 2006 10:58 PM
