Cam performance - Page 2
Old November 24th, 2009, 11:08 AM   #21
Stilleto Pumps in the club???
PeteAndersonRacing.com
Old November 24th, 2009, 02:38 PM   #22
tmoss's Avatar
tmoss is on a distinguished road
the advertised and then the .050" lift numbers give you an idea of the lobe. Which numers were the first you posted and do you have both? The inlet is pretty much unrestricted which in general means you don't need a lot of duration to make good power. Also the lobe center number would be nice as well as the ICL recommended.
some people just don't know what to ask, foregive them...........
88 GT Vert 5spd, 3:73 gears, Explorer intake/65mm TB, Explorer Ps, Manley race 1.85/1.55 valves, 1.7/1.6 stud rockers, stock cam +4 degrees, MAC Jet-Hot coated shorties. 277RWHP/330RWTQ www.fastlanecars.com http://tmossporting.0catch.com/
Old November 24th, 2009, 03:25 PM   #23
M L Struck's Avatar
85 GT/86 SVO/2010 GT500
M L Struck will become famous soon enough
@.050 241/250
lobe sep 104
i.c.l 44.5
"Having a 9 second neon is like coming out of the closet, everyone is shocked at first, but in the end you're still gay."
5.4 Shelby Crew member #1
Old November 24th, 2009, 04:58 PM   #24
Are you dead serious with that cam?
Nice overlap.. Shifting at 9000 ?
Good luck with power brakes.... Vacuum should be great.
With that lift ? That cam is way aggressive( Dwell) .... And probably an sadi core cam....So if you ran the proper spring need the cam will self destruct.
Where do you guys get these cams??? Flee markets?
Old November 24th, 2009, 05:44 PM   #25
JBIGBOOTSY's Avatar
1990 LX hatch
I'm just gonna throw this out there, but I am willing to bet someone just recently learned about billett cams????
And everyone knows a racer is only as good as his power brakes....
Old November 24th, 2009, 06:20 PM   #26
Keep running your turbo f cams sir.... lincoln log motors
Old November 24th, 2009, 06:27 PM   #27
M L Struck's Avatar
I think I will go back to that flea market or garage sale that I got that cam from and see if I can get some power for my brakes, and maybe some sadi core.
Old November 24th, 2009, 06:42 PM   #28
Should run 10's
Old November 24th, 2009, 07:57 PM   #29
M L Struck's Avatar
This has come full circle,so remember
"If you can't baffle them with brilliance, then bewilder them with bullshit."
Old November 24th, 2009, 09:59 PM   #30
1998 Cobra
13.24@105.66
Those heads and intake will flow a lot of air.. even with a stock h.o. cam it would prob run like a scalded dog. Why the 104 lsa.. seems rather aggressive.
Again, there are many "cam theories" and everyone is entitled to their own, but the track says it all.
weeee foooord!
Old November 25th, 2009, 12:16 AM   #31
Cam theories.......... ? There are theories? Hmmmmm
Old November 25th, 2009, 02:21 AM   #32
JBIGBOOTSY's Avatar
1990 LX hatch
Even if u test them?
Isn't an important factor in cam selection "compression ratio"? Or does a 200* lsa and 87* @ .050 theory apply to all compression ratio ranges?
Old November 25th, 2009, 08:03 AM   #33
tmoss's Avatar
Originally Posted by M L Struck View Post
i.c.l 44.5
are you sure about that?
lobe seperation angle (lsa) is the degree distance between the intake and exhaust lobe centers and is generally ~104-116 degrees
installed intake center line (icl) is the angle at which the intake lobe center is installed and is generally in the same range.
my guess is you don't have the cam card.
Old November 25th, 2009, 10:45 AM   #34
88-gt-t-top's Avatar
1988 GT
88-gt-t-top is on a distinguished road
so, can you guys stop will all the sarcasm and bullshit for a little so those of us that want to learn what all this means don't have to weed through the filth pouring from that hole in your face!!!
Thank you...
Originally Posted by 1slo5.0 View Post
You never save anything when you buy cheap off brand junk.
Originally Posted by e3sean View Post
its like taking a pill for a headach but the side affect is dihrrea, runny nose, blood clots, and aids.......well at least the headach is gone right......
Old November 25th, 2009, 10:54 AM   #35
ironsteed5.0's Avatar
91' 5.0 LX
ironsteed5.0 is on a distinguished road
Old November 25th, 2009, 11:19 AM   #36
M L Struck's Avatar
sorry my bad intake centerline 104
lobe seperation 108
Old November 25th, 2009, 11:28 AM   #37
1988 GT
lobe seperation 108
The lower the number the rougher the idle right?
Is this, mostly, what decides how the cam will idle?
Old November 25th, 2009, 11:59 AM   #38
M L Struck's Avatar
not sure about that, but the lower the number the quicker you get to peak power the wider, like 112 gives a more wide power range
Old November 25th, 2009, 02:24 PM   #39
Burn'nRubber's Avatar
1992 Mustang GT
Coming soon...
Burn'nRubber is on a distinguished road
I thought the higher the number the more vaccum and the better the idle. Thats the reason my engine builder recommended the xe270 with the 114 lobe separation instead of the 112. Not sure if I would have noticed much difference between the two, but I went with his word because he knows a thing or two about building motors.
1992 Hatch: 306ci, gt40p's, comp xe270, Edelbrock Performer, 1.6 r/r, full bolt-ons, and some supension work
Old November 25th, 2009, 03:04 PM   #40
How I understand it is like this
1: Intake & Exhaust Duration: This is measured in degrees of how long the valves are open. This number is rated at the camshaft and end result will be the same at the valve.
2: Intake & Exhaust Lift: This is measured in inches and in most cases this number refers to the valve lift and not cam lift. Valve lift is the measurement at the valve side of the rocker arm. This number is a calculation of cam lift with rocker ratio figured into the equation.
3: Intake & Exhaust Clearances: This is the recommended valve lash for these particular cams. The measurement is given in inches and the card explains that measurements should be done with the engine cold.
4: Rocker Ratio: The rocker ratio is the proportional relationship between measured lift at the cam and measured lift at the valve based on a rocker arms fulcrum point.
5: Duration @ .050: This is the U.S. standard of measurement. U.S.-spec cams are measured at .050 thousands of an inch.
6: Lobe Lift: This is the actual lift of the cam without the rocker ratio calculated into the equation. Cam lift is figured by measuring the cam from the tip of its ramp to the bottom of the base circle. Then measuring the base circle and subtracting the base circle measurement from the tip-to-base measurement.
7: Lobe Center: This is also referred to as lobe separation angle. Lobe center is measured in degree comparisons between the intake lobes and the exhaust lobes from the center of the camshaft.
Threads Similar to: Cam performance
Info on Big Cam Performance Please??? Speedstang302 5.0 Mustangs 4 August 7th, 2007 10:18 PM
staight line performance or track performance??? andoutcomethewolves V6 Mustangs 12 February 19th, 2007 11:34 AM
performance cam/stock heads? 1990CA50 5.0 Mustangs 17 February 6th, 2007 01:02 PM
E cam or F cam horsepower and 1/4 mile time questions GreyGhost 5.0 Mustangs 1 August 21st, 2006 06:25 PM
