Discussing EGR problem in the 5.0 Mustangs Forum. Ok i dont have an EGR system it was completely eliminated because of my 351 ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
EGR problem
Ok i dont have an EGR system it was completely eliminated because of my 351 heads. My check engine light stays on because of it and i've had it cleared before then the light is back again. Is there any way to stop the light from coming on, some way to bypass it, or to trick the computer that its there lol. Thanks for any advice.
Crate 302, Trick Flow Intake R, 75mm MAF, bbk 75mm throttle body, bbk 76mm EGR spacer, 351 Winsor heads ported and polished by Bennet Racing, Lunati cam, 30 pd. Injectors, TKO 500, aluminum drive shaft, bbk mid length headers, bbk off road H pipe, 3:55, |
95 opalfrost gt
You need to have it turned of in the pcm. either w/ a tweecer or other tuning device. Until the value in the pcm is turned off you will continue to get the CEL. The other method is to rig the plunger on the egr so its halfway down this will fool the pcm into thinking its functioning correctly and you wount get a CEL.
Threads Similar to: EGR problem
| umm have a weird problem? idle problem? | blue03mach1 | 99-04 | 16 | March 4th, 2008 01:03 PM |
| Has your car ever had a problem? | JASonic | The Clubhouse | 17 | September 19th, 2007 06:19 PM |
| big problem need help | 96gtponyred | 96-98 | 12 | August 22nd, 2007 02:36 AM |
| RIM Problem and Help | trueballerisme | 2005+ | 70 | August 21st, 2007 09:55 PM |
| TPS Problem? | 88Horseman | 5.0 Mustangs | 11 | November 14th, 2006 12:46 AM |
