piston question
Im looking at the 1,000,000 configurations that i could build out of a 306 block i have obtained....one question i had was how many psi could i run (without blowing the thing up) with flat topped pistons?
why are you using flat tops and planning boost?
1990 LX hatch
head cc, gasket thickness, milled or un milled block?
i havent even had the block magnifluxed yet....and no i wasnt necessarily thinking about flat topped, i was toying back and forth between running a higher compression or just supercharging it...
the kit i was looking at is from dss....331, forged all around, -13cc dish, afr 165's and about a 10psi sc...
might as well go 347...everybody else is gonna say that also
i have heard pros and cons about both but more pros on the 331...
And I heard Oprah is a Virgin ........
PeteAndersonRacing.com |
Whatever you heard is most likely wrong, get the 347 and don't go with dss
"Whip out your dick you'll either get it sucked or get smacked..." "That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
1990 LX hatch
Threads Similar to: piston question
| Quick question.. Checking Valve to Piston clearence.. | superbean | 5.0 Mustangs | 4 | July 17th, 2009 01:30 AM |
| Question about piston rings | iused2sk8in98 | 5.0 Mustangs | 3 | June 10th, 2009 11:11 PM |
| Piston Question with pictures ??????? | MOTOIMPAIRED | 5.0 Mustangs | 9 | April 20th, 2009 02:35 AM |
| Piston Question | bigbadtalontsi | 5.0 Mustangs | 5 | January 18th, 2007 12:20 PM |
| new motor prep nitrous/piston question | 173speed | 5.0 Mustangs | 11 | October 13th, 2005 12:37 AM |
