2500$
in complete what would be the best way to get power with 2500 dollars? im gettin about 4 thousand dollars and im looking at a used sc on here, but im definately getting some weld wheels and i wanna make some power, what would be the best thing to do with this money?
What do you already have?
I'd say to wait on the s/c. Make a good platform for that poweradder first. Especially if your getting 4 g's later, you'll be much better off finding a good one for 3-4 thousand rather then finding a really cheap one.
as of right now i have cai, pulleys, full exhaust (shorty headers, or h, flowmasters) and ford racing clutch. its a 6psi in the for sale section on here, and im looking for a 12 sec car not too crazy
Darrell will probably to you himself... get some heads, replace those rods and new intake
THE BEAST IS FOR SALE!!! GTX RACING & PERFORMACE CLUB OF TEXAS Meets and greets, drag racing and good eats, you know you want it. GTX Racing Tony P. 214-257-3635 http://www.moddedmustangs.com/forums...vehicle&CID=43 |
well let me say this, that there are a couple fox stangs with the stock motors n/a runnin 12's. and the big reason is suspension. and gears. get a full suspension done to ur car and then put some 373's or 410's and ur car will be hittin low 13's high 12's with slicks. but if ur bent on doin the motor, then i would say a good hci swap, get some gt40 heads port them out and they flow better than afr's and then get a trick flow cam stage 1 or 2, then a edy intake or holley, and u will have great car.
with all of this will i need throttle body? injectors? MAF? etc?
I think if you want 12 seconds, you'll have to put your fair share of time into the suspension. For $2500, I'd atleast get some different rear control arms to help you plant a little. Throw in some 3.73s then do as much of a HCI setup as you can. If you're stuck on forced induction, you need to buy parts that you'll grow into.
Hmm.. . .you may even want to look into a top end kit from Trickflow or Holley. That'd be the whole HCI setup and almost all of your budget, but then you'd only need to put the forced induction on and find a way to get traction. I thought I had some good suggestions, but now I just made me question myself ;-) Maybe you should wait to hear from some of the people here who have forced induction because if you don't buy good parts now, you'll either never live up to your power adder's potential or you'll have to buy them again. |
well i got 2 inch lowering springs, im not gonna be going to the track that frequently, so i guess i can say i want a car with power capable of 12's i really dont want to spent 2000 on suspension, so what mods that arent to expensive that would help most on susp should i get
Ask some of the pros around here, but upper/lower controls arms for starters, subframe connectors when you really make power and new shocks and struts. Someone may be able to tell you, from their experiences, how aggressive you want to get (90/10, 70/30, etc) if this is going to be your daily driver.
The control arms can be had for $170, subframes are half that. |
Also, I forgot to mention that depending on how serious you want to get about this, you can get into weight reduction / transfer. Alot of crap can be taken out of your car to lighten the ride. I don't think these Foxes had great weight distribution, so relocating anything from the front to the rear is a good idea. Battery relocation kits shouldn't be more than $50 from major suppliers, which is a cheap start.
There are also suspension parts (A arms, K member) that can be had to reduce weight, along with more expensive drivetrain parts (driveshaft, flywheel) but that's alot of moolah. You can also get aluminum brackets for the accessories in your engine to lighten things up. Alternatively, yanking shit out of your car and throwing it on the ground is free, so rear seats, carpeting, padding, spare tire and jack, smog system, etc are all fair game to wind up in the pile. |
yeah i want to keep the daily driver and keep it stock looking and everything. im not really gonna make a drag car out of this i just want a summer cruiser. its quick now and sounds and looks great, i just want that lil extra. thanks for all the input though. btw would these size wheels fit on a fox body i know nothing bout spacing or anything ...............................................Bol t Pattern: 4x100 or 4x114.3
Size: 18"x7.5" Offset: +43mm Finish: HYPER Black with polished lip
YEah you drive the car regularly too so don't get 4.10's. 3.73's are perfect setup. I got word yesterday that you can get rid of the quads and you can add a 15x10's with 6.5 backspacing so you can put to wides or "deep dish" on the rear.
yeah i was thinking 355 but after reading on here everyone seems to say 373 so im definately going with that, that will be my first think i do with the money and then ill probably get some sort of rims
#15 | |
and since cams don't cost that much.... THEN YOU CAN get your rims and order a cam while your at it. Although rims are lighter and will help your times just a tad. Make that not your major priority. Grab some good hp first, then make the car look good. You can see my profile, I got those heavy ass 94'ish rims from the older stangs and it's heavy, but I have no problem gettin them suckers smokey
Threads Similar to: 2500$
| RPM stuck at 2500 RPM? | Dawgfude03GT | 99-04 | 16 | October 3rd, 2007 09:21 AM |
| dodge 2500 | scxc15 | Drag | 7 | September 28th, 2007 07:44 PM |
| Vibration at 2500 RPM's and greater | Steves LX | 5.0 Mustangs | 7 | February 20th, 2007 07:49 AM |
| 2500 Stall Be Fine | tag team | 5.0 Mustangs | 8 | October 24th, 2006 10:11 AM |
