Discussing help with tach and speedo in the 5.0 Mustangs Forum. ive got an 89 lx notch 5.0 with the 85mph cluster the speedo is ...
Old February 20th, 2007, 09:03 PM   #1
ive got an 89 lx notch 5.0 with the 85mph cluster the speedo is off and the tach dosent work. where are the cables located on the tranny so that i can fix this...my tranny is leaking a tad bit, is that possibly from one on the cables? ...thanks
Old February 20th, 2007, 09:49 PM   #2
Well first off theres no cable for the tach it runs off your - (negative) side of your coil. But your speedometer cable is located on the drivers side mid-tranny. One bolt holds a u clip around the cable.
Crate 302, Trick Flow Intake R, 75mm MAF, bbk 75mm throttle body, bbk 76mm EGR spacer, 351 Winsor heads ported and polished by Bennet Racing, Lunati cam, 30 pd. Injectors, TKO 500, aluminum drive shaft, bbk mid length headers, bbk off road H pipe, 3:55,
Old February 20th, 2007, 10:39 PM   #3
thanks alot
Old February 20th, 2007, 10:52 PM   #4
now how do i adjust the speedo, is that bolt loose or what?
Old February 20th, 2007, 11:16 PM   #5
Well the the bolt out and check the speedometer gear for broken teeth or wear. If no signs of wear your gonna have to take you instrument cluster out and check your connection at the back of the gauge. Theres a white plastic clip thats around the cable holding it in place on the gauge. If your connections good then i would replace the cable it may be broken. I'd replace the cable before you re-install the instrument cluster if the speedometer dont work after checking everything. You would have to have the instrument cluster out to replace it any ways. Its not always the cable your gauge could just be broke UNLIKELY but possible.
Old February 20th, 2007, 11:17 PM   #6
I meant take the bolt out lol.
Old February 21st, 2007, 03:11 AM   #7
When I got my stang, when I was driving down the road you could usually hear this 'tick. . .tick. . ..tick .. .' like a clock. That was my needle bouncing from 0 to 140. Eventually I replaced the cable to the trans and the gear. Then my speed would only wobble +/-5 mph of my speed, maybe a little more. Usually more.
The guys I asked about said that after replacing that other hardware, the problem is in the speedo itself, on the back of the cluster. Unfortunately, I think I may have helped my speedo cable kink so now I have no speedo whatsoever. Static zero. But I still have my original tach going strong and that's all I need with my 5 speed. "No officer, I have NO IDEA how fast I was going. What's 4000 in 4th?..." etc.
So if you go fiddle with things, take a look at how the cable lies before you get started. Make sure it hangs back close to it's original location and of course if you remove it, run it back the way it came out.
Old February 21st, 2007, 12:16 PM   #8
well my tach is dead zero so i really need to fix that. people have suggested an external but i think they're tacky...thanks guys for the help i just got this car and before i had a camaro so i dont know anything about troubleshooting the stang. much appreciated
Old February 21st, 2007, 02:22 PM   #9
Tacky external???
Hop on summit and search for "Digital Speedomoter" and have a look.
THE BEAST IS FOR SALE!!!
GTX RACING & PERFORMACE CLUB OF TEXAS
Meets and greets, drag racing and good eats, you know you want it.
GTX Racing
Tony P.
214-257-3635
http://www.moddedmustangs.com/forums...vehicle&CID=43
Old February 21st, 2007, 09:06 PM   #10
alright it dosent look too awful bad, but if i have a working tach on my cluster...which i dont and am trying to fix...then i would go external
Old February 21st, 2007, 09:13 PM   #11
Asshole™
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Do you have different gears in the rear end? That will make your speedometer way off.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08
"he's traded his wheels for wings"
Professor of Natural Aspiration
Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft
Old February 21st, 2007, 10:42 PM   #12
nope its a 4cyl cluster and stock rear, the previous owner said its not off it just jumps due to the bent u-joint...and by the way how high on my list of things to do should the rearend be? it needs an 8.8, headers, powersteering pump, carb and paint in order to be ready for some poweradders. should i go rear then paint or vise-versa?
Old February 21st, 2007, 10:54 PM   #13
On Probation
Tony_90fox's Avatar
paint has never been important to me. I would take performance over looks anyday...Kinda like a sleeper to me.
MM Sapper Squad
Originally Posted by Regency 2007 View Post
MSO's stupidity has never stopped amazing me since the day he joined this forum.
Old February 21st, 2007, 11:15 PM   #14
yeah sleepers are nice. but on one hand, if the essentials are there to make it run good, why not make it look good right ups the value. On the other hand yeah just like you said somthing that out performs its looks by far would be great too. i dont know which way to go, how fragile is the 7.5 rearend i break somthing all stock?
Old February 21st, 2007, 11:31 PM   #15
On Probation
Tony_90fox's Avatar
I would put an 8.8 in there before anything...especially if you plan on modding it. I don't know if you have listed your mods or plans for the car...i forget easily...but an 8.8 would really be needed if you plan on modding this car.
MM Sapper Squad
Old February 22nd, 2007, 07:03 AM   #16
Asshole™
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Speedometer "jumping" is usually a bad speedometer cable.
Old February 22nd, 2007, 07:10 PM   #17
ok ill chech that out thanks
Old February 22nd, 2007, 09:31 PM   #18
Asshole™
Darrell's Avatar
1990 Mustang LX
9.36@143 mph
Also a "bent" u-joint will not have any effect on the speedometer reading.
Old February 22nd, 2007, 10:12 PM   #19
yeah i understand i thought that was a little out there.. he just thought since the whole car shakes that it had somthing to do with it but yeah im with ya thanks
Threads Similar to: help with tach and speedo
rpm tach ironhorse V6 Mustangs 14 July 14th, 2007 02:47 AM
tach? db83stang 5.0 Mustangs 10 April 15th, 2007 04:31 PM
tach notsoslo5.0 Want to Buy 15 January 11th, 2007 08:13 AM
tach notsoslo5.0 5.0 Mustangs 3 January 3rd, 2007 09:20 PM
A tach ???????? lugthug713 5.0 Mustangs 4 December 25th, 2006 03:49 AM
