Fuel Tank Pickup
Old February 20th, 2007, 11:28 PM   #1
screaming302's Avatar
screaming302 is on a distinguished road
Fuel Tank Pickup
i am converting an 89 5.0 to carb and was wondering about the aftermarket fuel tank pickups if i decide to buy one of these will i loose my fuel guage
Old February 21st, 2007, 08:44 AM   #2
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
You will be fine the sending unit and pump pick up are two seperate pieces in the tank. The sender is located to the left of the pick up when your looking at the tank.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old February 21st, 2007, 11:14 AM   #3
GTXRacing is on a distinguished road
The sending unit is located at the CENTER the EFI pickup is on the RIGHT. You need to buy an aftermarket pickup of course... DO NOT USE YOUR STOCK EFI PUMP WITH A REGULATOR.... DOES NOT WORK, YOU WILL FLOOD YOUR CARB!
THE BEAST IS FOR SALE!!!
GTX RACING & PERFORMACE CLUB OF TEXAS
Meets and greets, drag racing and good eats, you know you want it.
GTX Racing
Tony P.
214-257-3635
http://www.moddedmustangs.com/forums...vehicle&CID=43
Old February 21st, 2007, 08:02 PM   #4
i have heard alot of people trying to use there stock pump with a regulator but i wasnt sure if any of that worked i have put about 12 g's in this car i want it to be right the first time
Old February 21st, 2007, 08:18 PM   #5
gggggggggggg
Old February 21st, 2007, 08:37 PM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You can use the stock pump with the proper regulator but why would you want to use a stock pump? I would sump the stock tank instead of running one of those stupid pick up tubes that go in place of the stock pump. Those drop in pick ups don't allow the pump to be gravity fed and electric pumps should always be gravity fed.
Old February 22nd, 2007, 01:47 PM   #7
Also, let me revise my post.... You CAN use the stock pump, but be ready to return your gas back to the tank by using an FPR with two outlets. One for carb, the other to return excess gas. But Goes back to Darrells.. Why would you use the stock pump
GTX Racing
Tony P.
214-257-3635
Threads Similar to: Fuel Tank Pickup
GT Fuel Tank 07 STROKER 2005 - 2010 29 November 13th, 2007 08:37 AM
how do i find out how big my fuel tank is? nba1341 Classic Mustangs 4 October 31st, 2007 12:44 PM
Fuel Tank javier351lx 5.0 Mustangs 2 October 19th, 2007 02:30 AM
Need Fuel Tank Help mikebert 5.0 Mustangs 2 December 10th, 2006 11:43 AM
