glowshift gauges?
Old December 11th, 2009, 08:20 PM   #1
oscrfsh's Avatar
oscrfsh is on a distinguished road
glowshift gauges?
ok guys i am looking into replacing the gauges that are on my dash now..i want them all to match and i like the looks of the glowshift tinted ones. i know i know everyone says go autometer..but they are expensive and like i said i like the looks of the tinted ones. my question is are they pretty accurate, has anyone had problems with them, are the easy to instal...i have never installed gauges before...and i was also wondering if it is possible to keep the stock gauges hooked up also. i am looking into a oil press gauges, air fuel and temp gauge to mount in my 89s radio locationfor a nice clean look
thanks guys
Old December 11th, 2009, 09:55 PM   #2
HOLLYWD69's Avatar
07 GT/CS
12.12 @117.53 mph
HOLLYWD69 is on a distinguished road
I have use Glow shift with no problems. Gauges are a pretty easy install, you should have no problems with the install. and yes you can keep your factory gauges working.
See Garage for Mods
225-753-3966
Old December 11th, 2009, 10:24 PM   #3
oscrfsh's Avatar
do i just splice into those wires, i just didnt know if splicing into those wires would make the gauges reacd incorrect
Old December 11th, 2009, 11:10 PM   #4
Most gauges come with a few scotch locks to use.. they are much cleaner and easier to use then stripping and slicing wires together. They are the blue plastic squares in teh pic below
Old December 12th, 2009, 10:45 AM   #5
HOLLYWD69's Avatar
07 GT/CS
12.12 @117.53 mph
Depending on what gauges you are installing you will have to run new wire to the new sending units. You can't splice into the factory sending units.
See Garage for Mods
225-753-3966
Old December 12th, 2009, 04:43 PM   #6
oscrfsh's Avatar
oil press, temp gauge, and maybe air fuel
Old December 12th, 2009, 04:59 PM   #7
HOLLYWD69's Avatar
07 GT/CS
12.12 @117.53 mph
Oil pressure you will have to install a new sender in line with the factory one. I just removed the factory one put a tee fitting an installed the new on and reinstalled the factory one. Water temp you need to splice the sending unit into a water line under the hood. I used the water line that goes to the throttle body. Air fuel you have to have a bung welded into your exhaust for the sensor.
See Garage for Mods
225-753-3966
Old December 12th, 2009, 05:11 PM   #8
oscrfsh's Avatar
thanks maybe i will skip the air fuel
Old December 12th, 2009, 05:19 PM   #9
HOLLYWD69's Avatar
07 GT/CS
12.12 @117.53 mph
Yea its a little more involved. They are a must if you have some type of forced induction.
See Garage for Mods
225-753-3966
Old December 12th, 2009, 05:21 PM   #10
oscrfsh's Avatar
yea i just have a stock motor. im not looking into doing anything crazy...i think i might get a volt gauge instead of air fuel. are the glowshift tinted ones to small and hard to see if i mount them near the radio?
Old December 12th, 2009, 05:34 PM   #11
HOLLYWD69's Avatar
07 GT/CS
12.12 @117.53 mph
They should work good there.
See Garage for Mods
225-753-3966
Old December 12th, 2009, 05:38 PM   #12
oscrfsh's Avatar
k thanks for the input.
Old December 13th, 2009, 01:39 PM   #13
1988 Mustang 5.0 LX
12.48@118.27
ddarkslayer is on a distinguished road
I use those to but some of them can be a pain in the ass
Old December 13th, 2009, 01:52 PM   #14
HOLLYWD69's Avatar
07 GT/CS
12.12 @117.53 mph
Yea especially if you are in a tight spot!
See Garage for Mods
225-753-3966
Old August 20th, 2010, 11:19 AM   #15
Weidmansheil's Avatar
2005 Roush GT
Weidmansheil is on a distinguished road
Anyone have problems with their gloshift fuel pressure sending unit going out --last only 2 weeks and then puff gone?
"Sir, I do care! Just not about you"!
Old August 20th, 2010, 11:36 AM   #16
TylerMatthew10's Avatar
1995 Mustang GT
TylerMatthew10 is on a distinguished road
These gauges are nice i have had no problem with them on my triple pillar i have the volt, air/fuel, oil pressure
Old August 20th, 2010, 03:19 PM   #17
Authorized Vendor
Matt Cramer's Avatar
Matt Cramer is on a distinguished road
If you're unlucky, they can also cut the wire in two - or cut enough strands to have the wire break a ways down the road. I've used them a couple times myself, but they're not my favorite.
Old August 21st, 2010, 11:43 AM   #18
jake1191's Avatar
jake1191 is on a distinguished road
Send a message via AIM to jake1191 Send a message via Yahoo to jake1191
Autometer or Prosport are the two entry level gauges to buy. I know alot of people with glowshift gauges that crapped out in a week or less or just out of the blue dont read right any more.
Did you know there's over 435,000 tobacca an' alcohol related deaths last year? You know how many people marijuana killed? One. One dumbass who tried to hackysack a tarantula... -Rusty, from Squidbillies
Threads Similar to: glowshift gauges?
Glowshift Digital Tachometer & Shift Light - MSD Tach Driver moneygreenstang 99-04 1 February 23rd, 2009 04:30 PM
gauges Jucostud 2005 - 2010 37 December 23rd, 2008 01:04 AM
S/C Gauges Redfire07 General Tech 6 February 12th, 2008 10:46 PM
Gauges Bies08 V6 Mustangs 1 October 4th, 2007 09:25 PM
