1991 mustang 5.0
Vibration
I replaced my u-joints in april and still had a vibration after that. Well, I bought some pony rims with tires and it made it alot better because the old tires on my 10 holes were dry rotted and out of round. But now I still have a vibration at like 65mph. It's not steady but it wurrrrrs... idk how to explain it. My girlfriends dad said my u joints were bad while he was moving my driveshaft which i guess is not supposed to move at a stop lol. But also, when I'm cruising in 5th on the highway and I let off the gas abruptly, there's a loud bang noise and it jerks the car kinda. Should I just replace the u joints again?
#2 | |
1991 Mustang 5.0
Okay, u-joints. Pull your drive shaft and have it balanced. Check your rear-end yoke, rear gear slack, and transmission output bearing (will cause your 'bang', also). Aside from being with the car, that's what I can think of.
"Seek to understand before you seek to be understood." Unknown "Life's tough...it's even tougher when you're stupid" John Wayne |
#3 | |
![]() I don't have vibrations though.
1991 mustang 5.0
I have a vibration that sounds the same as yours just it doesent start tll around 80 or 90
The Big Spoon
88 5.0 5 Speed Notch <><
never fast enough
if your vibe is at 65, it may be a wheel balance issue. will the vibe be gone above 75? i had this problem and it was the wheel balance. i am doing u joints today though because they are making grinding kind of vibe.
also, if your vibe is of a higer frequency it is the drive shaft. if it is a lower frequency, it is a wheel. |
1992 Lx
11.39@119.24
could be alignment slightly off, 1-4 wheels off balanced, drive shaft, or just the fact the fact the cars old as fuck and falling apart
#8 | |
1991 mustang 5.0
#9 | |
1991 mustang 5.0
And the driveshaft isnt supposed to move at all when you mov eit with your hand right? |
#10 | |
The Big Spoon
never fast enough
there will be play in the rear a little from gear backlash |
#11 | |
1992 Lx
11.39@119.24
1991 Mustang 5.0
Did you have the wheels/tires speed-balanced?
1991 Mustang 5.0
Just BARELY. When you get the driveshaft balanced, have the yokes checked for true. I've seen folks spring the yokes changing u-joints.
i had the worst vibration issues ever...i bet if you put in a new aluminum driveshaft they would be gone
1991 mustang 5.0
1992 Lx
11.39@119.24
just when you grab it and rotate it back and forth, itll have slight play there
1991 mustang 5.0
Threads Similar to: Vibration
| Vibration? | brianm | 2005 - 2010 | 44 | September 2nd, 2009 11:09 PM |
| vibration | grnstang | 5.0 Mustangs | 0 | April 12th, 2009 11:25 PM |
| vibration | kreil45 | 5.0 Mustangs | 16 | October 27th, 2008 03:20 PM |
| Vibration | shurb125 | 5.0 Mustangs | 13 | May 8th, 2007 09:23 AM |
| vibration | cali 5.0 | 5.0 Mustangs | 7 | June 8th, 2006 07:44 PM |
