Removing rear drums
Old December 15th, 2009, 01:23 PM   #1
Firaga's Avatar
1993 Mustang GT
Firaga is on a distinguished road
Removing rear drums
Okay, I'm replacing the shoes, and I cannot figure out how to remove the drums. The bolts are extremely tight, and WD40's not helping too much. I can't fit a ratchet behind there, so I have to use a standard wrench...
Is there a specific way to remove these... :-/
Old December 15th, 2009, 01:28 PM   #2
1992 Lx
11.39@119.24
bolts wtf? you see that wheel looking thing at the bottom? that adjusts how far out the shoes are, adjust the shit out of it and they should pop off, otherwise hit around the edges from behind with a hammer, its really simple
Old December 15th, 2009, 01:31 PM   #3
nolife's Avatar
91GT, 88GT, 02GT
There are no bolts to remove except the lug nuts and the wheel, the drums should slide right off. Make sure the car is sturdy and you have the e-brake off. If the e-brake is off and they still do not come off, you will have to lossen the self adjusters with a small flat screwdriver or tap on the drum with a mallet. Further direction and more detail can be given if that is the case. Its too late now but never use WD40 anywhere near the brakes, drums, or rotors.
EDIT: By e-brake off, I mean the handle in the car is the whole way down, not the e-brake cable or anything like that.
Old December 15th, 2009, 01:31 PM   #4
1992 Lx
11.39@119.24
and is your name the fire magic from final fantasy?
Old December 15th, 2009, 02:33 PM   #5
Awesome Sauce
Mr_Will's Avatar
92 Mustang LX
Mr_Will is on a distinguished road
Send a message via AIM to Mr_Will Send a message via MSN to Mr_Will Send a message via Yahoo to Mr_Will
Sounds like he was trying to loosen the backing plate bolts
U.S. Army Retired
Owner: Crankgoboom Racing
James G. Bilkey - "You will never be the person you can be if pressure, tension, and discipline are taken out of your life."
Old December 15th, 2009, 06:54 PM   #6
laztug's Avatar
1993 Mustang GT
laztug is on a distinguished road
Mine had some clip like things holding the drum in place....they screwed where the lug nuts bolt on too. We hit them counterclockwise with a screwdriver and a hammer.
Stock 5.0 Motor M/T Drag Radials
E.T.- 13.859
MPH-97.23
60 foot-1.853
Old December 15th, 2009, 07:59 PM   #7
Firaga's Avatar
1993 Mustang GT
Haha, yes. I think I've been using this name since I was probably 12... LOL.
So, I took the drums off, and they were so badly worn down. In addition, the rear left cylinder was leaking fluid, it was everywhere inside the drum, and like suspected the shoes were pretty much bare metal.
So, to make this less of a clusterfuck for me, seeing as I (obviously) know nothing about brakes, I decided the best thing to do would be to take it in to my mechanic.
It'll come out to about $250 with parts and labor... It's a price, but I'd rather avoid (further) headache. Getting those springs back on, along with the drums was a major pain in the ass.
Plus, considering these are the original drums... well.. what can you expect?
Old December 16th, 2009, 07:58 AM   #8
Awesome Sauce
Mr_Will's Avatar
92 Mustang LX
if you have the time you can probably put together a rear disk setup for around that cost.
U.S. Army Retired
Old December 16th, 2009, 04:33 PM   #9
1991 Mustang 5.0
WDfrmTN has a little shameless behaviour in the past
That's not a bad price, if he includes flushing the whole system.
"Seek to understand before you seek to be understood."
Unknown
"Life's tough...it's even tougher when you're stupid"
John Wayne
Threads Similar to: Removing rear drums
removing rear seat and rear moulding? 07 STROKER 2005 - 2010 11 April 26th, 2008 04:17 PM
Rear Sway / Stabilizer Bar removing dreamr 5.0 Mustangs 4 April 23rd, 2008 11:47 PM
removing rear sidemarker lights JaxnsGT 99-04 2 December 22nd, 2007 05:13 PM
89 5.0 rear drums! dmachine22 General Tech 1 October 19th, 2007 08:45 AM
Removing rear seat Murderjetz V6 Mustangs 28 July 19th, 2007 10:07 AM
