92' 5.0 LX (Not starting)
Old December 16th, 2009, 03:15 PM   #1
1992 Mustang Lx (Droptop)
roushman90 is on a distinguished road
Send a message via AIM to roushman90
So heres the thing. I just traded my other car for my aunts 5.0 that has been sitting since July 09' due to it "stopping". She says that it just quit running one day, and she told me a mechanic said something about the computer being bad or a chip...So first thing I think, it needs new ECU? Oh, and it's an auto BTW.
When I got it home, it didn't even have power, battery was dead, so I swapped in another good battery and all the lights and everything work. BUT, the car just cranks but won't turnover. Mind you, this a very healthy, virgin Mustang. New off-road h-pipe exhaust, new rad, fresh battery, A/C delete.
So, is there any way to test the ECU?
My other thought is it could be the distributor?
Old December 16th, 2009, 04:31 PM   #2
1991 Mustang 5.0
WDfrmTN has a little shameless behaviour in the past
Begin with the simple things, first.
Powers, grounds, etc..
Obvious fuses/fusible links/relays
Ignition switch.
TFI module.
If you wind up needing it, son has a C3W EEC (89-93 for auto).
"Seek to understand before you seek to be understood."
Unknown
"Life's tough...it's even tougher when you're stupid"
John Wayne
Old December 16th, 2009, 06:41 PM   #3
I forgot to mention that I am new to Mustangs, and well, domestics really. I've tinkered for a few years with Imports (240sx), but finally found a nice 5.0.
I checked all the under steering wheel fuses. I checked for spark, apparently not getting spark. Fuel pump primes. I was just wondering if there is ANY way I can take the ECU out and test it. The rotor on the dizzy does move, but I'm not sure how to tell if the dizzy is bad....
Edit: Don't know if it matters, but the firing order is correct. I'm currently looking for the fuel pump fuse.....
Old December 16th, 2009, 10:10 PM   #4
83 5.0's Avatar
83 5.0 is on a distinguished road
Here are some wiring diagrams that may help you out. American or foreign, all trouble shoot the same way, look for spark, fuel etc. you will figure it out if you give it enough time.
Mustang FAQ - Engine Information
Good Luck
Old December 17th, 2009, 01:52 AM   #5
86er's Avatar
if it has no fire, check the TFI module. grey block that sits under the dist with the connector on it.
simple and common problem
Just a truck
Old December 17th, 2009, 03:20 PM   #6
Thanks
Old December 19th, 2009, 09:55 PM   #7
How can I check the TFI module?
Old December 20th, 2009, 09:10 AM   #8
93mustanglx is on a distinguished road
Take it to an Advance Auto store. They have testers for those.
Old December 27th, 2009, 08:47 PM   #9
817B!GT3X is on a distinguished road
How to Solve an EFI No Start
This helped solve my "No start issue"
Old December 28th, 2009, 10:34 PM   #10
87 MUSTANG GT
12.87@107
electricblue87 is on a distinguished road
Send a message via AIM to electricblue87
It Is Most Likeley The Ignition Module.it Will Happen To Every Mustang At One Time.
Threads Similar to: 92' 5.0 LX (Not starting)
92' GT question So_calpsycho 5.0 Mustangs 11 October 7th, 2009 06:43 PM
what kind of headers should I get? 92' 347 duckfart 5.0 Mustangs 37 February 13th, 2008 07:35 PM
clutch problem in a 92' 5.0 red_baron243 5.0 Mustangs 5 January 7th, 2007 01:38 AM
clutch problem in a 92' 5.0 red_baron243 5.0 Mustangs 0 January 5th, 2007 09:18 PM
92' Mustang GT 5.0 arc590 5.0 Mustangs 5 December 23rd, 2006 07:34 PM
