GT40P Heads
HI, Wondering if these heads are worth $300 ? These heads came off an 1996 ford explorer. The heads have a gt40p stamped on the inside. Casting number on the bottom of the heads is F77E. These heads have been vatted, steel blasted, magnafluxed, and pressure tested. Also have 3-angle valve job, new valve stem seals, and have been milled. I can purchase them for that but was wondering if they would work for me. I know that I would be limited on what headers that I could use..Would I be better off with long tube headers or the shorty ones ?
I plan on getting roller rockers..1.6 or 1.7 ??? Not sure on which to get.. A new GT40 Intake, upper and lower, Underdrive pullies, CAI, Will use stock injectors for now. I have an automatic trans and will probably go with 4.10 gears. What other upgrades would be a good match for what I have listed..? I really would like a good street car with an occassional trip to the dragstrip and not be laughed at...Not really concerned about fuel mileage as it will only be used for short trips back and forth to work.. Thanx for any input that you might have.. ![]() Tom Last edited by lakefrontlivin; December 17th, 2009 at 09:49 AM. |
1988 lx
9.68@142
300 isnt bad for prepped and ready set of p heads that is about 300 alone in machene work. the matching explorer intake will work just fine and should bring you in the 12's with a set of gears
#3 | |
1986 lx notch
9.98 @ 135
![]() " Spending money I don't have.... on things I don't need .... to impress people I don't know " . |
1.6 or 1.7 rockers? Thx, Tom
If anyone would like to pm me with suggestions as to which way that they think that I should go as far as mods please feel free. ![]()
the Comp Cams XE270-12 cam has made good power for that combo. Make sure the springs are set up right.
88 GT Vert 5spd, 3:73 gears, Explorer intake/65mm TB, Explorer Ps, Manley race 1.85/1.55 valves, 1.7/1.6 stud rockers, stock cam +4 degrees, MAC Jet-Hot coated shorties. 277RWHP/330RWTQ www.fastlanecars.com http://tmossporting.0catch.com/
Thanx for the advice Tmoss.. What do you mean about the springs being setup right? Should I bring them to a shop and maybe install better springs? Thanx Tom
1993 5.ohhhh
12.97 @140mph
When you select your cam, bring the cam card to a machine shop, and they can tell you what springs to buy. Worst case, you sell the old springs. I'm sure 9000 people on corral will want the old ones.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
Well,
I bought the GT40P heads.. Now to get an intake setup next.. Thanx for the advice guys..![]() Tom |
Comp cams XE series have very steep ramps and even Comp tends to not recommend enough spring to handle rpms over ~6k.
1988 lx
9.68@142
i think 93 mustank has a good custom cam set up for p heads and explorer intake get with him.
#11 | |
I'd expect he would have thrown that cam in the trash can. See if he'll tell you what a mistake your making with those parts..........
If I stay with the stock cam in my car should I go with the 1.6 Roller rockers or the 1.7 ones ?? This would be using the stock springs on the GT40P heads..Is this an option ?? Thanx, Tom
1988 lx
9.68@142
no get better springs even if your using a stock cam.
Sold it all ..................
PeteAndersonRacing.com |
Love you Tom
Awesome!
is that a new car TMOSS???
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
it's a 40th anniversary 2008 Shelby GT500KR that I bought last fall.......
Hi Guys. Would 1.7 RR work with the stock cam setup and stock springs on these GT40P heads???? Thanx , Tom
1992 Lx
11.39@119.24
do you keep saying stock springs as in stock explorer springs? because theyre garbage
Yes stock springs as were on the GT40P heads.
I'll look into getting better ones.. I think TMoss suggested some Trickflow ones at one point.. Will I be able to run the 1.7's without any issues? Should I buy pushrod giudeplates ? Will I need new pushrods? What's agood place to maybe pickup these items up all at once ? Thank-you, Tom
Threads Similar to: GT40P Heads
| gt40p heads | jtyson8602 | 5.0 Mustangs | 15 | January 14th, 2009 08:00 PM |
| 351W heads vs gt40p heads? | mustangsoldier | 5.0 Mustangs | 16 | December 10th, 2008 11:00 PM |
| gt40p heads?? | 5.0 Calypso | 5.0 Mustangs | 10 | March 20th, 2007 10:45 PM |
| GT40P Heads | dr.gonzo! | 5.0 Mustangs | 20 | January 10th, 2007 11:44 AM |
