Wierd Spark Near Starter Solenoid Switch and Battery???
Old December 18th, 2009, 09:41 PM   #1
91Stang5.0's Avatar
1991 Ford Mustang GT 5.0
91Stang5.0 is on a distinguished road
I'm getting a pretty good sized spark when I crank the engine over somewhere near the Starter Switch Solenoid and the Battery. The car starts fine, but the spark wierds me out. I really can't tell where its coming from since I'm looking into the engine bay from the cab, but I do notice it coming from somewhere either at the Solenoid switch, Battery, or Battery Ground (the little wire coming from the neg to fender wall) or between them somewhere. Any thoughts? I have no one here to help me when finding where the spark comes from. I've looked at everything and it all looks good to me. I've checked all I can check without replacing something.
1991 Mustang GT 306 - Built AOD w/External Cooler, 4.10s, TF Stage 1 Cam, TF Intake, Pro Comp Heads, Pacesetter LT Headers, BBK CAI, 10:1 Comp, Too much to list inside the engine......Turbo or Super Charger coming soon
Old December 18th, 2009, 10:41 PM   #2
meh
Notcho's Avatar
Notcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to behold
Send a message via AIM to Notcho
Make sure the starter relay (solenoid) has a good ground, (bolted down solid) and the negative battery cable is grounded well. If the spark only occurs when you go to start it, the only thing that is being used is the starter relay (solenoid)
Otherwise you can put the tranny in NEUTRAL and jump the two large posts on the starter relay with a screwdriver to see if you can see the same spark again when you are standing there.
PS... wasn't your car on craigslist about a year or so ago..? That picture looks familiar..
'87 2.3 Notch with +4 cylinder mod
Ass, Cash, or Grass.. nobody rides for free
Black Stang Crew Member #11
Old December 19th, 2009, 03:26 PM   #3
91Stang5.0's Avatar
Yea but it wasn't my car. I bought it lol. The picture however was never on craiglist. Yes the spark on occurs when I start it. I've also put it in neutral and get the same spark.
Old December 19th, 2009, 03:30 PM   #4
aka Nature boy
sickfox's Avatar
blk 89/red 91 XJ Limited
I like turtles
sickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant future
He just said put it in neutral so you can get out of the car and jump the solenoid. Just use a screwdriver and touch the two post at the same time.
Black Stang Crew Founder #-1
MM+Cleavage Club #15
www.xjor.org
I would drag my dick through a mile of broken glass just to hear her fart through a walkie talkie
Old December 19th, 2009, 05:36 PM   #5
91Stang5.0's Avatar
I found the spark and fixed it. It was a ground from a small wire that comes from the negative terminal and goes on to the fender wall between the starter relay solenoid and the battery. It was somewhat loose.
Threads Similar to: Wierd Spark Near Starter Solenoid Switch and Battery???
Starter solenoid clicks at the starter but wont start the car?? 95StangSVT 94-95 13 March 11th, 2010 10:22 PM
starter solenoid???? Iwannagofast 5.0 Mustangs 8 February 26th, 2008 01:10 AM
How can u tell if its the starter or the solenoid? noyz25 5.0 Mustangs 11 October 28th, 2007 09:48 AM
Starter/solenoid problem WIKD 2.3 Mustangs 2 October 4th, 2007 07:15 PM
Starter solenoid? 8A_Honda 5.0 Mustangs 9 March 13th, 2007 12:23 AM
