wont run when put in drive
Old December 23rd, 2009, 05:19 PM   #1
1965 Ford Mustang
01dutchGT is on a distinguished road
Send a message via AIM to 01dutchGT Send a message via Yahoo to 01dutchGT
I have a 1992 mustang gt. I have had some problems with it recently. When the car is at idle, the car runs fine but when i put it in drive, the engine wants to shut off and has left me stranded on the side of the a few times. What should i start looking for. Ive replace sparplugs but what else should i start to replace? What sensors or MAF. It has new EGR and Throttle body as well as cold air intake.
any help would be greatly appreciated.
2001 mustang gt 5 speed
Full bolt ons with 4.10 gears.
1965 Mustang
302 with 4 Barrel edelbrock 600cfm, T5 transmission, Hurst short throw shifter.
In the process of restoring it...
Old December 23rd, 2009, 05:24 PM   #2
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
is 90 a MAF setup??
Old December 23rd, 2009, 05:37 PM   #3
93mustanglx is on a distinguished road
I would check your codes before you spend a bunch of money on parts you may not need.
It could be your TPS
Old December 23rd, 2009, 06:11 PM   #4
USMC8511's Avatar
1990 MUSTANG GT
13.55 @100.64
USMC8511 will become famous soon enoughUSMC8511 will become famous soon enough
TPS doesn't that make it idle up and down even in park...?
Old December 23rd, 2009, 08:15 PM   #5
2001 Mustang 4.3 V6
strictly6racing is on a distinguished road
vacuum line misrouted or not connected.
2001 v6---R.I.P.
479hp and 530tq with 15 psi and N2O
http://www.cardomain.com/ride/3119170
88 mustang 5.0---build underway
http://www.cardomain.com/ride/3806455
Old December 23rd, 2009, 09:39 PM   #6
Not always. Did you check you codes?
http://fordfuelinjection.com/?p=13
Old December 23rd, 2009, 09:39 PM   #7
1965 Ford Mustang
found out it was the fuel pump.
1965 Mustang
Old December 23rd, 2009, 09:45 PM   #8
Was it not keeping up? Make sure it isn't your fuel pressure regulator.
Definitely go for the upgrade it is worth the extra money.
http://shop.advanceautoparts.com/web...S_267355739___
Old December 23rd, 2009, 09:45 PM   #9
USMC8511's Avatar
1990 MUSTANG GT
13.55 @100.64
usually they just quit working....
Old December 23rd, 2009, 10:00 PM   #10
I have seen a lot of them suck the boot in and plug the pump. It just depends on their age and if they sat for a while with bad fuel or not.
But they usually just stop working all together.
Old December 25th, 2009, 03:29 AM   #11
1988 Mustang 5.0 LX
12.48@118.27
ddarkslayer is on a distinguished road
I've heard cases where some people drive with low oil then drive and the motor gets beaten up so much to the point where it idles then when you put it in to drive it dies
Threads Similar to: wont run when put in drive
Need help for a friend, car wont even hardly run bkg97gt 99-04 7 May 10th, 2009 02:23 PM
87 gt, different motor, wont run right, ecm??? highrider407 5.0 Mustangs 20 March 30th, 2009 09:04 PM
car wont run gyellow 5.0 Mustangs 6 May 30th, 2008 08:46 PM
98 Cobra Wont Run nasty92LX 96-98 6 April 8th, 2008 09:53 AM
'91 hatch wont run, please help '91 4-cyl hatch 2.3 Mustangs 14 August 9th, 2007 01:08 AM
