1990 mustang lx
13.04@105
fuel pressure on 30 lbs injectors
im curently runing 30 lbs injectors and i just put a bbk fuel pressure regulator, and i was wondering what should i put the pressure at? right now its at 30 at idle.
1988 Mustang 5.0 LX
12.48@118.27
I feel like thats a little low I would go with 35
1988 Mustang 5.0 LX
12.48@118.27
but yea like they always say leaner is meaner
1989 GT
KB 2.1L Flowzilla
I take it thats with vacuum, if it's not knocking sounds good. I have 30lbs with stock fpr, 32psi with vac, 39 without. You could try to bump it up a bit and add some timing, find out what is the fastest setting. Can't give an exact answer because all setups respond differently.
1988 GT
for sure, try and throw some timing at it and see how she responds... keep giving timing and fuel in small incriments until there's no more to give aka doesn't run any better.
#6 | |
1990 mustang lx
13.04@105
Threads Similar to: fuel pressure on 30 lbs injectors
| Fuel injectors lbs question | snosourfur | Modular Mustangs | 7 | October 29th, 2009 01:55 PM |
| 24 lbs injectors and a fuel pump... | b-on-b 5.0 | 5.0 Mustangs | 7 | October 21st, 2008 10:24 AM |
| Fuel Pressure Regulator Leaking Fuel | Buttaz | V6 Mustangs | 4 | August 17th, 2007 11:41 AM |
| Fuel Injectors/fuel pressure | 00silvergt | 99-04 | 4 | August 2nd, 2007 09:54 AM |
| No fuel pressure, Fuel gauge went above full and stayed. | woodz72 | 96-98 | 6 | July 10th, 2007 06:58 PM |
