c4 shifter
Old December 28th, 2009, 10:59 AM   #1
5mustang0 is on a distinguished road
c4 shifter
i"m doing a engine swap in my 1985 mustang and it had a v6 with a c5 transmission and thats the same thing as a c4 but a lock up convertor and i bought a c4 to replace it but it doesn't have the shifter lever on the transmission so i tryed to take the one off of the C5 but i couldn"t how do you do this???
Old December 28th, 2009, 02:48 PM   #2
Proud American
MustangMatt96GT's Avatar
you got to take the valve body out of the transmission to get the shifter linkage out... and then when putting it back in you got to put it in the correct ridge on the valve body. IE put the valve body all the way forward or all the way back and same with the linkage and you should be set.
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old December 28th, 2009, 05:49 PM   #3
okay thanks!
Threads Similar to: c4 shifter
Shifter moves when going over bumps with the rear (stock shifter poly bushings) Avengence 2005 - 2010 5 September 3rd, 2009 10:42 PM
Hurst shifter rattle on new shifter Odin 2005 - 2010 8 January 11th, 2009 12:18 AM
New shifter 96GtGoodz 96-98 37 January 28th, 2008 09:40 PM
Best Shifter 06RedfireGT 2005 - 2010 10 August 9th, 2007 11:45 PM
Shifter RC02GT 99-04 20 March 17th, 2007 04:12 PM
