Discussing bullet wheels hitting front control arms in the 5.0 Mustangs Forum. I need help with 5 conversion, 4 wheel dics, and bullet wheels, Now i have ...
Old February 23rd, 2007, 04:43 PM   #1
I need help with 5 conversion, 4 wheel dics, and bullet wheels, Now i have limited turning radius and wheel hitting front control arms
Old February 23rd, 2007, 04:48 PM   #2
Hitting when you turn, go straight, hit a bump...?
THE BEAST IS FOR SALE!!!
GTX RACING & PERFORMACE CLUB OF TEXAS
Meets and greets, drag racing and good eats, you know you want it.
GTX Racing
Tony P.
214-257-3635
http://www.moddedmustangs.com/forums...vehicle&CID=43
Old February 23rd, 2007, 04:52 PM   #3
the inside of the wheels are hitting the control arms when turing, I have a limited turning raidus now
Old February 23rd, 2007, 04:56 PM   #4
SALIV8's Avatar
do u have stock control arms?
Old February 23rd, 2007, 05:02 PM   #5
yes, ns95 balljoints, 99 pindles, stock control arms
Old February 23rd, 2007, 05:04 PM   #6
Sorry new at the forums, might not answer back quickly but i am trying.
Old February 23rd, 2007, 05:08 PM   #7
SALIV8's Avatar
How wide are the wheels??? they're obviously widerthan stock. why not go back to skinnier?
Old February 23rd, 2007, 05:09 PM   #8
Re: bullet wheels hitting front control arms
I should have mentioned the car was lowered approx 2 " by the previous owner, Adding the 2006 bullet wheels and tires filled the wheel well, and with the 2 " drop has created the control arm rub,
Old February 23rd, 2007, 05:12 PM   #9
SALIV8's Avatar
the drop won't matter i dont think, unless it rubbing the body. the wider wheels are the issue. have u bought or thought about a spacer? BUT now the lowering might b an issue. u can buy the spacers prolly at a parts store by u about 15 bux.
Old February 23rd, 2007, 05:18 PM   #10
The drop affects the angle of the control arm slightly, body rub does not seem to be a problem, spacers would offset the wheel and cause the fender rub. I heard about grinding the pad on the control arm?
Is there anything else besides this. I thought about bringing the height back to stock or notched control arms$$$
Old February 23rd, 2007, 05:23 PM   #11
SALIV8's Avatar
I can't think of anything unlessu get slimmer fronts. Or raising the car a litle--would any size spacer give u the fender rub? they have different sizes and some down to very thin how bad is the rub EDIT- how bad is the control arm rub?
Old February 23rd, 2007, 05:31 PM   #12
The rub is considerable, turning into my drivway riped off inside wheel balance weight. Maybe slight spacer and minor grind on control arm???
Old February 23rd, 2007, 05:35 PM   #13
SALIV8's Avatar
I would be weary of cuttin the stock control ams too much. they suck cause they're friggin so huge. I replaced mine-they're monsters. i would meaure the fender clearance, see about the spacer and u might get lucky?? then i might grind the lip of the control arma little.
Old February 23rd, 2007, 11:29 PM   #14
Mr_Evil's Avatar
Gah', how wide are your rims? The offset may be too far in.
Old February 24th, 2007, 12:18 AM   #15
homebrewed's Avatar
'88 LX body '91 GT D/T
8.7 in the 1/8th
You might try adding just a very slight bit of negative or positive camber to the adjustment. I am having the EXACT same issue on my 91 Notch. Its has 17x8 wheels w/ 245/45 Tires and a 2" drop as well. I am not overly familiar w/ OEM vs Aftermarket "A" arms and their relative thickness. That may be a solution. A set of wheel spacers may add just enough distance to keep the inner portion from rubbin. I have a 1/4" set and will throw them on tomorrow and see how it fairs. If the tires will clear the wells, then... BAM! Problem solved. I'll let ya know.
Founder of the I don't like my shit centerd and want it back the way it was dammit! club
www.myspace.com/evoalliance
greatest band alive
Originally Posted by Tony_90fox View Post
I wish there was a :lickmynuts smiley, because i would use it now
:lickmynuts
Old February 24th, 2007, 03:06 AM   #16
Mr_Evil's Avatar
I have 17x8 with 245's in the front and they never rub the control arms. I had to roll my fender though because the car is lowerd 2". On rare occasions if I was driving rough in a parking lot I could get them to rub the inner wheel well. I have now removed the inner wheel well plastic part though for more upper clearance. I will have 255's in the front with my next set of tires.
Old February 26th, 2007, 05:25 PM   #17
I have 17x9 2006 bullet wheels. Well now I did grind off the pads on the front control arms. I did pick up additional turning radius. I still have some wheel rud on the front control arm. I must have at least 2.5" drop on the front wheels. I can only think the drop affects the clearance on the wheels. With having to replace the springs, would spring spacers work temporaryly???
Old February 26th, 2007, 08:37 PM   #18
Mr_Evil's Avatar
I doubt it is the drop. I bet your wheels offset is to far in.
Old February 26th, 2007, 09:29 PM   #19
Kingcater's Avatar
I read in a mustang mag that the 2005+ stang wheels are actually have a better offset for our cars than the 94-04. Why not swap out to 94-95 controll arms and see if that helps the rubbing issue.
2000 A4 Z-28 Free Mods
No Appearance or Performance mods
Yea, it's slow.....
Old February 26th, 2007, 11:21 PM   #20
Will the 94-94 fit? Sounds like a good solution....
Threads Similar to: bullet wheels hitting front control arms
steel control arms vs aluminum control arms Saleenwolf720 99-04 1 October 15th, 2007 02:32 PM
Upper Control Arms & Lower Control Arms LUV2XLR8 2005+ 6 October 6th, 2007 12:45 PM
Front Control Arms gotboost562 5.0 Mustangs 8 September 20th, 2007 01:28 AM
Steeda lower control arms (Trailing arms)? kmjsmith 2005+ 6 July 4th, 2007 05:59 PM
front hubs and control arms, anything else while its apart? markush Suspension 0 May 21st, 2007 03:03 PM
