Transmission Problem?
hey every one im new to modded mustangs... i just purchased my first mustang an '88 gt... in first gear it runs fine, in second and third there is kinda light grinding noise, in fourth and 5th it runs smoothly,yes i do know how to drive standard.. what can it be??? not properly alligend clutch?
Ricer, ricer wat you gunna do , what you gunna do when mustangs come for you |
The syncros are prob worn or something. Change fluid and see if shifter is adjusted correctly if it an aftermarket one. Some if not all of them have an adjustment for the shifter stops..
does anyone know how many quarts of tranny fliud t5s take...do they use syncro mesh??
1990 LX hatch
2 3/4, I believe
I have a Tremec 3550 in my car it takes 3 Qts. of Syncro-Mesh. I am not sure about a T-5
#6 | |
The T5 maintenance manual (found at http://www.ttcautomotive.com/English...er/product.asp) states: "Most T5 transmission models use Dexron II automatic transmission fluid. Refer the vehicle owner’s manual or service manual for lubricant specifications." My 1991 Mustang owners manual states Mercon. Dexron III replaced Dexron II and both are fully compatible with Fords version called Mercon. Basically, Mercon and Dexron III are the same thing. Funny thing though is that Google searches for T5 fluid type will turn up possible suggestions for just about every type and brand of manual and AT transmission fluid ever made. Even plain old gear oil. Ouch. Quantity? I changed mine out and I believe it took almost 3 qts.
Thanks
Thanks i have another question... is lucas transmission oil good?.. i fxking love all you people
so pretty much if i go syncro-mesh or dextron it wouldent hurt correct
run the specified transmission fluid. Dexron III
#10 | |
Unless you have a modified/rebuilt T5 and the person that modified it specifically suggests something else (and is willing to back up their work), I'd stay with Dexron III/Mercon. Although... a lot of people use Synchomesh in a T5 as well. I'd don't feel comfortable enough with "I've used Synchomesh with no problems and so has my friend" as a reason to use it myself. To each his own I guess.
now i have another freaking problem.. i was out just cruising around get home about to park and call it a night, as i pull up to parking spot motor stalls.. then after that i start the car like usual but a wierd noise from the fuel pump... i reved the motor to 1200rpm then i hear a knocking noise and motor just cuts off what can it be...???
Knock-Knock??? Who is there? Nothin good thats for sure!!!!
yay no more knocking!
Threads Similar to: Transmission Problem?
| Transmission problem help please | jtlogruss08 | 94-95 | 6 | November 3rd, 2007 12:58 PM |
| Transmission or Clutch problem ? | cobralini | 5.0 Mustangs | 7 | May 23rd, 2007 11:44 PM |
| 2004 Automatic Transmission Problem | bdoss | V6 Mustangs | 0 | January 10th, 2007 01:43 PM |
| Transmission Problem | 623MUSTANG | 99-04 | 4 | August 10th, 2006 03:29 PM |
| Transmission Problem | 173speed | 5.0 Mustangs | 6 | April 13th, 2006 10:57 PM |
