Need Help A.S.A.P! (Starter)
just yesterday i finally droped in a 393 in my 87 fox! its a dart block, 8:1, w forged internals, a prochrager f1-r, and a C4 automatic with a sfi bellhousing. the problem i am having is the dam starter! the original starter i had doesnt fit because of the headers. the headers i am using are kooks. i was told a 94-95 starter would work and fit perfect. it did fit good but the gear does not reach the flywheel. so i orderd a powermaster starter and it was them same shit!! it didn't reach again, so summit told me theres 2 problems either i have the wrong size flywheel which is a 157 teeth or the wrong bellhousing... the starter i got was for a 164 teeth.
ANY SUGGESTIONS!! THANX!!
95 TURBOCHARGED COBRA 87 BLOW-THRU FOX |
Sounds like the flywheel is a 157 tooth and the bellhousing is for the 164 tooth. Call the bellhousing manufacturer and find out what bellhousing you have. You might have to get another one. I'm reasonably certain that is the problem.
all motor
92 coupe
9.94@136.40
DAMN!!!!!! f1R- dart w/8:1 comp.,393 ci !!!!!!!!!!!!!!
JEEZ u'll break the damn sound barrier!!!! what's ur goal 8.50s??? Please pm me pics when that rocket isdone...... PLEASE! |
#4 | |
#5 | |
all motor
92 coupe
9.94@136.40
Awesome
whereis the pics?
THE BEAST IS FOR SALE!!! GTX RACING & PERFORMACE CLUB OF TEXAS Meets and greets, drag racing and good eats, you know you want it. GTX Racing Tony P. 214-257-3635 http://www.moddedmustangs.com/forums...vehicle&CID=43 |
this is the 393 8:1 dart block
![]() the final setup
dear god im in love.
haha you could count the teeth, or spend a billion dollars on a mini starter.. sorry for your luck... but sweet ride.
92 lx 351W w/ 60 overbore holley 600cfm carb weiand stealth dual plane intake 240/246@.510 cam bbk long tube headders msd coil 5 lug axle conversion 3.55 gears mach1 style 17" rims |
#11 | |
id be better off strapping a rocket to my car wiley cyote style if i was thinking about running 9s
all motor
92 coupe
9.94@136.40
WOW. Nice set up
i just orderd a csr starter hopefully it will work and i will finally get to fire up the beast!
Threads Similar to: Need Help A.S.A.P! (Starter)
| I think my starter is going... | JustinSane | V6 Mustangs | 24 | November 1st, 2007 05:30 AM |
| starter | notsoslow50 | 5.0 Mustangs | 6 | August 21st, 2007 10:47 AM |
| STARTER help please!!!! | Replica R | Audio/Video | 3 | June 25th, 2007 03:02 PM |
| Starter for my car! | dblindberg | 2005 - 2010 | 8 | January 12th, 2007 08:10 AM |
| Starter or Starter Relay | cobralini | 5.0 Mustangs | 7 | August 3rd, 2006 06:34 PM |
