Bondo or not to bondo HELP!
Old February 24th, 2007, 11:54 PM   #1
Tr1gger is on a distinguished road
Hey guys, just picked up a car and im changing out the carpet. After ripping it out I realized on the floor around the drivers seat rail, the floor is rusting out and there is a 3X2 inch hole. I was thinking about bondo-ing the hell out of it to fill it in. Would tha work? Or do I have to go with another method?
Old February 24th, 2007, 11:58 PM   #2
JBIGBOOTSY's Avatar
1990 LX hatch
fiberglass sheet and resin.
Old February 25th, 2007, 12:01 AM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Cut all of the rusted metal out and section in a piece of good metal. Weld it.
Old February 25th, 2007, 12:02 AM   #4
would that be the strongest/best idea? I wanna avoid any welding as well.
Old February 25th, 2007, 11:10 AM   #5
86blkmustang's Avatar
86blkmustang is on a distinguished road
Send a message via AIM to 86blkmustang Send a message via Yahoo to 86blkmustang
Cut ur rust out like Darrell said cause bondo won't stop it from rusting. Cut it out weld a new piece in and throw some rustoleum paint on to it the ur done for a long long time.
Old February 25th, 2007, 11:33 AM   #6
redalert89 is on a distinguished road
yup you cant fix rust unless you cut it totally out.
Old February 25th, 2007, 04:16 PM   #7
Dell's Avatar
Dell is on a distinguished road
If ya can't weld it i'd go the fiberglass route (as mentioned above)...
.Cut out all the rust.
Grind clean (nice and shiny) the surrounding area, top and bottom (under car if it's exposed)
Clean with a good degreaser
Apply fiberglass matt and resin in layers, top and bottom (make each layer a little bigger than the last)
If you got the tools should only cost ya around $20/$30 for the glass/cloth
good luck
Old February 26th, 2007, 01:06 AM   #8
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
If you don't want to weld it, find someone who will. It'll be a lot better in the long run.
O o
/¯/______________________
\_\
Old February 26th, 2007, 10:58 AM   #9
FIVE-0's Avatar
FIVE-0 is on a distinguished road
Send a message via AIM to FIVE-0
+1, its stronger and it'll last longer
Old February 26th, 2007, 07:59 PM   #10
speedy431 is on a distinguished road
definitely take the time out to cut it out and then weld it with good metal. will last a lot longer than the cheap fiberglass method. the rust will go right through the fiberglass
308, 13.5:1, TW heads, GT-40 Intake, QA1 front kit, UPR Pro rear, Aluma-stars, Pro-Stars rear, 10.95@120, 1.40 60'
Threads Similar to: Bondo or not to bondo HELP!
Fiberglass bondo Tr1gger 5.0 Mustangs 13 March 15th, 2007 08:51 PM
