My whole car started shaking... Really bad vibrations ???
I started my 94 gt mustang this morning and It started vibrating bad. It vibrated a little less after it warmed up but still way more then normal. No weird noises. Temp in normal. It vibrates really bad at all speeds. What did I break?
1994 Mustang Gt convertible Cobra R rims Bassani X pipe & flow masters Upgraded Sterio System |
2001 svt cobra
no way (IRS)
If you have a 94 I sure it has a 5.0, Mine did the same thing and I found that the harmonic balancer was going(or went) bad. This is the item that sits behind the crank pulley. Mine started to separate and actually came apart, made the engine look bad major vibration.
Build #1249 MM New Edge Crew Member# 6 |
mine shook real bad and i found that the u-joints had alot of play in them ..it worked
Mine shook horribly after it rained so i replaced the distributor cap and rotor and it was fine.
Temp was normal, bat level normal, no check engin or other lights, accelertated noamal everything. It was mainly vibrating at the main part of the engin from what I can see. I can really feel it in the stick shifter. When I first started it cold it vribrated bad but then settled down a little as it warmed up. I notice it a little less when its idleing.
When mine shook really bad, it turned out to be the driveshaft & u joints.
Man, once those were changed out, a big difference.
Have you driven a Ford lately ?
#7 | |
well it doesnt do it anymore after replacing the cap and rotor but i will look into u-joints and harmonic balancer.
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
thats exactly what mine did when my harmonic balancer went out, mine didnt look worn or anything though but you could look at it and tell it was off....
Threads Similar to: My whole car started shaking... Really bad vibrations ???
| Really bad vibrations | mustangchris | 5.0 Mustangs | 5 | October 7th, 2007 07:20 PM |
| my car is shaking? | villatic | V6 Mustangs | 44 | June 22nd, 2007 10:09 PM |
| vibrations | 89beastin | 5.0 Mustangs | 8 | April 16th, 2007 02:11 AM |
| Car shaking below 1500 rpm | 90Stang | 5.0 Mustangs | 5 | August 25th, 2006 02:40 PM |
| Shaking Problems | garyvang | 5.0 Mustangs | 3 | May 10th, 2006 08:04 PM |
