holley fuel pump problem
Old January 12th, 2010, 11:11 PM   #1
McMustang5.0 is infamous around these parts
So I was running my holley fuel pump at 6psi to see if i had to replace any fuel lines. Well I noticed a small leak under the car after parking it. I smelt it and it was gas. Now its turned into a big leak. Its leaking outa the corner, all the bolts are tight.
Is there a gasket that coulda gone bad?
Old January 13th, 2010, 10:23 AM   #2
86er's Avatar
yes, youll need to buy the pump rebuild kit
Just a truck
Old January 13th, 2010, 10:58 AM   #3
cool, thx!
Old January 14th, 2010, 06:11 PM   #4
86er's Avatar
glad you got it worked out
Just a truck
Old January 14th, 2010, 08:14 PM   #5
actually, i installed it today and fuel leaked out worse!
My plate on the bottom is bent and when I replaced the gasket it didn't help so I called holley and they are sending me a new plate FREE!
Old January 14th, 2010, 08:29 PM   #6
86er's Avatar
that works, nothing beats havin a pretty much new pump for the cheap and free
Just a truck
Old January 15th, 2010, 10:14 AM   #7
hahaha, yeah, I uses both kits and now I get a new plate, totale cost $30 should preform like new!
Threads Similar to: holley fuel pump problem
Fuel Pump Problem!!! Please Help!! Mr.Stang08 2005 - 2010 26 April 27th, 2009 10:52 AM
***Need Help*** Fuel pump problem?!?!? Mluna08 99-04 24 March 6th, 2009 11:22 AM
holley blue electric fuel pump skidze 5.0 Mustangs 9 October 3rd, 2008 02:39 PM
Fuel Pump Problem? chaosstangman 5.0 Mustangs 3 December 19th, 2007 11:39 AM
holley red electric fuel pump ?? ujslost 5.0 Mustangs 5 December 1st, 2007 11:24 PM
