1993 Mustang 5.0 LX
11.45@122.34
FMU with 42lbs?
should i totally take out the fmu when i put my 42lbs injectors in or should i keep it hooked up just for extra fuel? I dont think it will work, because the disk in the fmu is only calibrated for 19lbs injectors. So should i just completely ditch the fmu? and just run the 42lbs injectors?...and if anyone needs some 24lbs i have a set for sale for $150 bucks for all eight they were installed in march of last year
i really dont think that will work....you need to have a tune when you add the 42s...
1993 5.ohhhh
12.97 @140mph
The 42lbers are there so you don't have to run an fmu and smaller injectors. As stated, you will need a tune.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
An FMU is not technically calibrated for specific injectors, it "multiplies" fuel pressure with boost based on the disc that is in it and with some the slope is adjustable. Either way... Like stated, if your getting new injectors, get the correct ones for your HP and ditch the FMU. Where ever your going to get tuned, get their opinion on using the stock ECU with 42 or larger injectors specific to what kind of idle quality they can achieve. That is about the point where a standalone should be considered and I'm sure every different tuner has a different opinion.
1993 5.ohhhh
12.97 @140mph
Yeah, Idk if it was the 42's, my lmaf, or my tuner, but my idle was all over the place. I hated it. Wheres the best place to order tweecer rt?
Im curious to your set up thats calling for 42lb injectors not doubting, just curious
1993 5.ohhhh
12.97 @140mph
he has a V3 strim. I think it put down close to 400 at the tire on 24lbers.
#8 | |
oh and the obx abaco meter I have might have a big part in that as well |
You can use an FMU with 42 lb injectors, and yes a FMU can be calibrated.
You want the 2:1 disc and ring in there. But it is probably not required with the 42 lb injectors if you get a good tune.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
Could yall enlighten me on what a FMU is? I know about carb's but I just recently learned about EFI! any more abreviations for some stuff on a EFI car?
BTW:B-on-B, toss that sh*t and convert to carb! Jk, my friend says you can run the FMU but you need to get it Flashed (<--???) and reprogramed for the 42#injectors. |
i dont think your friend knows what he is talking about
Authorized Vendor
![]() Join Date: Sep 2008
FMU: Fuel management unit. Similar to a rising rate fuel pressure regulator. It raises fuel pressure, but instead of adding one psi of fuel pressure for 1 psi of boost, it might add 10 psi of fuel pressure for every psi of boost. Generally, they're used to add fuel on turbocharged or supercharged cars when the injectors are too small to supply enough fuel at full throttle and standard fuel pressure.
Yeah, maybe there was a mix up on three letter acronyms there, he might of thought the discussion was about ECU or the computer, not the FMU?
There are only 17,576 three letter acronyms so its easy to mix them up
hahaha, i'm ging to give him shit, he was all acting smart the rest of the day too.
Tomorrow I'm going to give him a big fail poster! LOL. |
1993 Mustang 5.0 LX
11.45@122.34
alright thanx guys and yea i am getting the injectors next week, with the right sample tube for the maf i have and guna get it tuned like the week after...the guy said he would burn a chip and custom tune it for 600 even
1993 Mustang 5.0 LX
11.45@122.34
yea and my tuner said to ditch the fmu set up cuz i wont need it
1993 5.ohhhh
12.97 @140mph
Damn! I paid 200 for a chip and 300 for a tune.
1993 Mustang 5.0 LX
11.45@122.34
reli is that a good price? might try this other company for a quote
Threads Similar to: FMU with 42lbs?
| 42lbs Of Badassness! | texasd18e | 99-04 | 5 | January 26th, 2008 01:00 PM |
| What to use other than FMU? | 8A_Honda | 5.0 Mustangs | 7 | October 3rd, 2007 10:45 AM |
| fmu | mmvi | V6 Mustangs | 14 | June 4th, 2007 05:13 PM |
| fmu help | angermgt | 5.0 Mustangs | 7 | March 25th, 2007 10:19 AM |
