what are the pros and cons f rear coilovers?
Old January 15th, 2010, 06:40 PM   #1
1989 LX coupe 5.0L
89lx is on a distinguished road
i searched and couldnt find any good info just wondering if they would work good for the strip and street
Old January 16th, 2010, 11:37 AM   #2
EscortSportage's Avatar
1989 Mustang GT 5.0
cons...price
pro....list is to big
really coilovers are the way to go for top suspension weather u wanna drag race or autocross it all depends on what springs/shocks u run coilovers are where its at
lighter,better setup,better geometry, adjustable, ....
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
"a huge bad azz motor is nice untill you have to turn or stop"
Old January 16th, 2010, 12:01 PM   #3
JBIGBOOTSY's Avatar
1990 LX hatch
Cons: price and not really needed.
Pros: better tire clearance, adjustable ride height, and adjustable dampening (in some).
Old January 16th, 2010, 03:08 PM   #4
1989 LX coupe 5.0L
well i just bought the upr front k member kit with coilovers and i need new rear springs so i was thinking about just getting rear coilovers. i just dont know anyone with rear coilovers to ask if they like them or not. i mostly drive it on the street but this year i wanna go to the strip as much as i can. thanks for the info
Old January 16th, 2010, 07:00 PM   #5
The Big Spoon
jessemachone's Avatar
88 5.0 5 Speed Notch <><
never fast enough
jessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of light
I am thinking that you will have to reinforce the mounting point on the body. I could be wrong but that will be a lot of weight suspended at such a small mounting point on the body.
Old January 16th, 2010, 07:24 PM   #6
1989 Mustang GT 5.0
yes for the rear coilover setup the kit comes with a reinforcement piece, because the factory setup its not designed to take all that weight, the spring and control hold most of the weight, You can use bilstein and koni shocks with coilovers in rear, there are prolly more u can use but those are the ones off the top of my head
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
Old January 16th, 2010, 11:57 PM   #7
rear coil overs isn't popular with street driven mustang owners.. not really sure why and never looked into the cons because i'll never pick them up because there not really needed and having all the tension on the top mounts doesn't sound nice to me.
Old January 17th, 2010, 11:26 AM   #8
ryans88gt's Avatar
The shock towers can handle the weight no prob. The little bracket on the 8.8 needs to be replaced or reinforced.
main con is price and not really needed
main pro is adjustability. Also it allows you to run a dual heim joint lower control arm without a spring perch. The dual heim joint control arm allow much more articulation of the axle so it will perform much better without any suspension bind. However, running a antiroll bar with this setup is highly recommended for drag racing.
Just doing this setup myself, so I've done a bit of research on it.
The strange coil over kit is a pretty good deal. The complete setup with aluminum body adjustable shocks is around $400. With dual adjustable shocks $600
Threads Similar to: what are the pros and cons f rear coilovers?
3.73 pros and cons? fasterv6 V6 Mustangs 24 August 12th, 2009 10:03 AM
pros and cons zinc02GT The Clubhouse 11 June 24th, 2008 12:28 AM
3v swap. Pros and Cons. RAGEman 99-04 23 April 18th, 2008 05:38 PM
Pros and Cons of the V6 05 SDS V6 Mustangs 137 March 24th, 2008 08:49 PM
Pros And Cons Of Lowering hotrod General Tech 14 March 22nd, 2008 09:20 PM
