Fuel Lines
in the next few weeks ill be lookin for a 351w for my fox and its going to be carbed, my question is what do i have to do from the tank itself all the way to the carb
85 svo. work in progress
i left the original pump in the tank. i found a regulator from summit that was a heft sum, but it fit my needs perfectly.. i cut the old lines up front where they flex and flanged it out, then through a series of adapters and hose which i really just made up on the spot.. i had it all set up. i suggest highly getting this regulator.. making use of both your pressure and return lines.. and getting a fuel pressure guage to take up the second outlet from the regulator. itll help you when you need to set it all up anyways.
AEI-13204~ regulator ATM-4411~guage ATM-3227~ braided hose i was bound and determined not to use a mechanical fuel pump.. and i really didnt want to dig into the tank to run a new line or change out the pump.. so i started looking. at first, i just had a t block that broght the pressure at the carb down to around 6. but that just wasnt reliable enough. good luck
92 lx 351W w/ 60 overbore holley 600cfm carb weiand stealth dual plane intake 240/246@.510 cam bbk long tube headders msd coil 5 lug axle conversion 3.55 gears mach1 style 17" rims |
can i use an electric pump but use the original lines, ive heard if you put a regulator on an efi pump with a carb it will eventually leak
'88 LX body '91 GT D/T
8.7 in the 1/8th
The only thing I have seen and done is a complete fuel system upgrade. All Aeromotive. Everything. From the pump to the rails to the fittings. It works flawlessly. The A1000 will power nearly anything. I advise against mixing and matching old with new; and brands. Ie; Earls and Aeroquip. BBK and Aeromotive, etc.
Have you ever done a fuel system? If so, you got a pretty good idea whats in store. If not.... Heheheh..... Have fun puttin the fittings on the line
Founder of the I don't like my shit centerd and want it back the way it was dammit! club www.myspace.com/evoalliance greatest band alive |
Threads Similar to: Fuel Lines
| Braided Fuel Lines | gotboost562 | 5.0 Mustangs | 11 | October 11th, 2007 04:01 PM |
| Fuel lines | JBIGBOOTSY | 5.0 Mustangs | 2 | August 31st, 2007 07:10 PM |
| Removing fuel lines? | Tony_90fox | 5.0 Mustangs | 3 | July 7th, 2007 11:39 PM |
| Do I Have To Swap The Fuel Lines? | OTreborO | General Tech | 1 | November 9th, 2006 08:31 PM |
| fuel lines | 2ToneFox | 5.0 Mustangs | 3 | August 7th, 2006 06:16 PM |
