Battery Wont Charge While Car Is Running Need Help Please!!!
Old January 31st, 2010, 03:52 AM   #1
1988 mustang hatchback
88sbcmustang has a little shameless behaviour in the past
so i have an 88 2.3 mustang and when the car is running the alternator wont charge the battery and iv had the alternator checked it was good iv replaced the plug on the alternator cause i heard they go out and the battery is a good battery i cant find a wiring diagram anywhere i need help PLEASE!!! i just wanna drive my fox
Old January 31st, 2010, 05:00 AM   #2
Imran's Avatar
01
Imran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud of
try out a new alternator anyways. If still it does not work, return it.
Old January 31st, 2010, 08:45 AM   #3
87StangGT's Avatar
1987 Mustang GT
87StangGT is on a distinguished road
Check voltage when the car isnt running should be around 12v then check it when it is running with nothing on (radio lights a/c) it should raise to about 13-14v. If it doesnt then its a bad alternator. its possible the guy at the auto parts place didnt know what he was doing and the alternator is in fact bad. has happened to me before.
Like Jakashh said go buy one you can always return it.
Old January 31st, 2010, 10:28 PM   #4
it starts at 8 with nothing on and it just drops when Im driving untill the car just dies
Old January 31st, 2010, 10:53 PM   #5
Imran's Avatar
01
seems like your alternator isn't charging.
Old January 31st, 2010, 11:23 PM   #6
i take it off and have my local parts store test it and it charges just fine though is there a fusible link somewhere i missed?
Old January 31st, 2010, 11:51 PM   #7
perry2k12 is on a distinguished road
my buddy had the same problem and went and got his alternator tested at the parts store. they said it was ok. guess what the problem turned out to be in the end? alternator
Old February 1st, 2010, 08:00 AM   #8
Zip Your my Hero....
fastback lover's Avatar
1988 Mustang LX
N/A
fastback lover will become famous soon enough
I would have to agree with the alt. When I used to work at checkers we were told to make the alt. and starter pass if it would mean a warrenty return. If you want to belive the parts guys then follow the wires and make sure they are in good shape. But take the alt. to napa. They are normally good about the test.
Old February 1st, 2010, 02:28 PM   #9
cusp's Avatar
2008 Mustang GT
cusp is on a distinguished road
Is the voltage regulator built in to the alt? If not then check that too. The VR works by regulating the field current. If there is no FC, there will be no alt output.
2008 manual GT with deluxe trim, FRPP CAI, FRPP GTB Mufflers & 91 All Out Tillman Tune. 3.73 gears, Coast Ultralight Drive-shaft. 18" OEM Polished Bullitts, Webelectric Sequentials, XM built into the Shaker 500. Alarm and Escort RedLine.
Old February 1st, 2010, 05:45 PM   #10
87StangGT's Avatar
1987 Mustang GT
Yep its the alternator.
Old February 7th, 2010, 04:59 AM   #11
Angry
Replaced the alternator with a brand new one still aint workin is there a wiring diagram for the charging system i could get somewhere or is there just something im missing all i know is that this really sucks
Old February 7th, 2010, 09:26 AM   #12
87StangGT's Avatar
1987 Mustang GT
EDIT: Other link did not work this one should.
http://www.veryuseful.com/mustang/te...nks-ign-ac.gif
Try this...
Did you get the right alternator for your car?
Also check all you wires make sure you have nothing backwards, check the voltage at the back of the alternator. Possibly have something backwards or have a bad diode in the alternator which could also cause short in the battery somewhere. if it has a bad diode you could take it to the parts place and it will test good all day test good but don't work if one or more of the diodes inside are bad.
but try the wire diagram see if that works for you.
Old February 7th, 2010, 04:35 PM   #13
1989 mustang 5.0 5spd
14.0 guesstimate
necro5.0 is on a distinguished road
It sounds to me like your battery is bad, it should read at least 12.8 volts with the car not running, and it shouldn't drop past 12 while you're cranking the engine. If it's dropping to 8 volts then it's either bad, or about to be... also check your voltage regulator if you have one that's external of the alternator...
Old February 7th, 2010, 10:52 PM   #14
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
bad ground maybe?
1990 GT
Pro 5.0, 3.73s, TFS Intake, Flows
2004 Impala SS
Supercharged(stock), DD
2001 Tacoma
2.5" Lift, K&N cai, TB Spacer, Magnaflow, Elec. Fan, Stereo MODS!!
Originally Posted by JBIGBOOTSY View Post
my table spoon engine is bigger than the tea spoon engine!
Old February 8th, 2010, 12:07 AM   #15
1989 LX coupe
calgarynotch is on a distinguished road
personaly if any fox mustang owner has any charging or alternator problems....do yourself a favor and do the 3g swap with a good napa premium unit and 4g wire to the solenoid. as far as i know the alternator trigger wire runs into the volt gauge. mine came loose behind the cluster and wouldn't charge either after i did my swap
Old February 25th, 2010, 09:37 PM   #16
Cool
i tried and tried and finally said f*ck it and bought a 3g alternator and wiring harness fixed everything
Threads Similar to: Battery Wont Charge While Car Is Running Need Help Please!!!
Battery Wont Charge MIGHTYJO3YOUNG 5.0 Mustangs 5 January 31st, 2010 10:58 PM
Running way rich, and wont hold a charge. flattusmaximus78 5.0 Mustangs 15 October 24th, 2009 07:24 PM
c4 swap an battery relocation now car wont turn over bretts95gt 94-95 17 March 23rd, 2009 07:42 PM
car wont Stay running 01dutchGT Classic Mustangs 8 April 23rd, 2008 02:42 PM
Car wont stay running Spiderz Classic Mustangs 10 March 8th, 2008 08:14 AM
