B cam with twisted wedge heads
Old February 27th, 2007, 07:26 PM   #1
Holy Dick Castle!
dr.gonzo!'s Avatar
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
dr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant future
I like the sound of the b cam but I dont know if it will work with twisted wedge heads w/c having to cut the pistons
Old February 27th, 2007, 07:43 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Throw the B cam in the garbage and get a cam that will actually make some power. A B cam will work fine with Twisted Wedge heads because it is barely any bigger than a stock cam.
Old February 27th, 2007, 07:47 PM   #3
Holy Dick Castle!
dr.gonzo!'s Avatar
so E cam or T/W stage 2?
Old February 27th, 2007, 07:48 PM   #4
foxstang is on a distinguished road
i love my f-cam.
89' 306 W/ Edelbrock performer 5.0 heads, BBK SSI intake, F-303 cam, 75mm MAF, 75mm TB, 30lb injectors, 255lph fuel pump, BBK afpr, BBK shorty headers, Off road X-Pipe, Flowbastards, and 3.73 gears.
Old February 27th, 2007, 07:51 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by dr.gonzo
T/W stage 2?
Much better choice!
Old February 28th, 2007, 09:11 AM   #6
Moderator
89StangGT's Avatar
SVT Cobra Mustang
89StangGT has a spectacular aura about89StangGT has a spectacular aura about
Send a message via AIM to 89StangGT
the trick flow stage 2 was designed to make power with TW heads. so that cam is probably your best choice. the "letter" cams are kinda out of date now.
There's a reason Ford codenamed them the Terminator
Old March 1st, 2007, 11:18 PM   #7
ih8chevy is on a distinguished road
the only thing wit the stage 2 cam is that u will need gears cause of the power band, and u might wanna check the ptv clearance. for the 5.0 block its a huge cam, 542/563 lift. im trying to run it too and its a risky cam cause of the size. good luck
Old March 2nd, 2007, 12:11 PM   #8
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You should always check piston to valve clearance with any cam change. That is a no brainer. However, the design of the Twisted Wedge head allows running a 2.02 valve with a mild cam and stock pistons. A .542/.563 lift cam is far from huge. 15 years ago that was huge but these days it is not. .800 lift is huge. I've run this Trick Flow cam in many engines with no problems at all.
As far as gears go, that is the first thing anyone does to their Mustangs anyway so there really isn't an issue there. I'm sure he has 3.55 or 3.73 gears already.
Old March 2nd, 2007, 03:20 PM   #9
Holy Dick Castle!
dr.gonzo!'s Avatar
cool. I thought I had seen a post on here where a guy was having trouble with the stage 2 cam but I dont know what his setup was. I do have 3.73. I havent changed the spedo gear so 70mph is 140 to me. I dont know if the gear change is what caused that or he did something when he installed white gauges
Old March 2nd, 2007, 03:51 PM   #10
Moderator
89StangGT's Avatar
SVT Cobra Mustang
im not sure i have white gauges that go to 160 and it says im doing 150 when im doing 70 with 4.10s and a 26 tall tire. the gears will cause it to be off a bit i just dont think that much. i think the white gauges go a higher mph than stock ones.
Old March 2nd, 2007, 05:47 PM   #11
Holy Dick Castle!
dr.gonzo!'s Avatar
I still cant decide if I want to get rid of this convertible and get a hard top. It alredy has 3.73 gears and a valve body shift kit cai and I think larger injectors for some reason.
Old March 2nd, 2007, 05:51 PM   #12
It just depends on what you want to do with it man. Just a daily driver or do you want to take it to the track all the time. I mean there are some fast verts out there, but you have to meet more strict specifications for dragging. I believe you have to get a cage alot earlier and stuff like that.
I personally do not like verts, but man it is your car and have probably grown attatched to it. I know alot of people do not like my hatch, but what do i care, I am in love with it. The decision is up to you.
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old March 3rd, 2007, 12:34 PM   #13
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Gears make a big difference in speedometer accuracy.
Old March 3rd, 2007, 07:31 PM   #14
dude ur auto already has the work done to it that u need i would keep that thing, unless u hate drivin auto. the verts are a bit heavier but i love the way they look. all u need is nice motor setup and ur there. oh and fyi, ur auto trans the way it is will beat any similarly setup stick on the road, once u get a 2800 stall.
Threads Similar to: B cam with twisted wedge heads
trickflow twisted wedge heads conrad 5.0 Mustangs 24 October 22nd, 2007 09:33 AM
twisted wedge dr.gonzo! 5.0 Mustangs 3 January 26th, 2007 02:46 PM
