Drag Suspension Setup?
Old February 28th, 2007, 06:40 PM   #1
5.0newbee is on a distinguished road
I have a 93 LX and I want to set the suspeneion up right. I really want to lower it but I fear that with less rebound on the spring, that it would kill my 60ft. The only racing that I would be doing is drag, so Im not worried about cornering. I have 17in Cobra R's w 275/40 drag radials and 373's. Like I said before I really want to lower it 1.5-2inches, so what is the best way for me to set my suspension up?? Also I dont want to spend an arm and a leg on suspension parts
Thank You
Scott
O yea, my car is pretty much my daily driver
Old February 28th, 2007, 06:42 PM   #2
Moderator
89StangGT's Avatar
SVT Cobra Mustang
89StangGT has a spectacular aura about89StangGT has a spectacular aura about
Send a message via AIM to 89StangGT
well lowering it and using 17 inch cobra Rs and drag racing dont really go together. my car stock other than 4.10s with cobra Rs and street tires lowered went 14.10 but with 15 inch weld wheels and slicks it went 13.89
There's a reason Ford codenamed them the Terminator
Old February 28th, 2007, 08:37 PM   #3
JBIGBOOTSY's Avatar
1990 LX hatch
I have 4cyl. springs and 90\10 up front no sway bars and lakewood traction bars. My car pitches alot during turns but it is not that bad the struts make it ride like a coupe de ville, the only good adj. drag struts are the ones that you can adjust rebound, and compression seperately$$$, I have stock control arms and stock bushings and the car launches good. low 1.80s for low 13s N/A. I can even fit a piece of paper under my driver side front tire. The 4cyl springs lower the car just a little too.
Old February 28th, 2007, 10:04 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Lowering the car will not hurt it as long as you don't use a weak low tension spring to do it.......usually. But those 17 inch wheels with tires that don't have any side wall aren't helping you at all.
Old February 28th, 2007, 11:54 PM   #5
Stangzilla's Avatar
Stangzilla is on a distinguished road
Yeah I have 17 in R rims also and it is impossibe to have a good 60' time anyway.. I have to use slicks.. I am not sure but I would think that if you do lower the car you might have rubbing issues if you decide to run a slick..
Get upper and lower control arms, get rid of the swaybars and if you can afford it get a set of the Strange Engineering adjustable struts and adjustable shocks. I used to have Lakewood 90\10's on the front and 50\50 on the rear and without the sway bars it was way to "washy" for me. Those Strange units are awesome soft at the strip and stiff on the street.. Makes up some on not having swaybars.. And if you are gonna race someone on the street then give-em a couple of clicks and your ready...
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old March 1st, 2007, 08:00 AM   #6
Moderator
89StangGT's Avatar
SVT Cobra Mustang
+1 on the strange 10 way adjustables. and lowering your car would make problems for running a slick unless you stick with a 26 tall tire.
Old March 1st, 2007, 11:27 AM   #7
El Conquistador
whiteboycustom's Avatar
83 coupe
whiteboycustom is just really nicewhiteboycustom is just really nicewhiteboycustom is just really nicewhiteboycustom is just really nice
Send a message via AIM to whiteboycustom Send a message via Yahoo to whiteboycustom
i want to run a full aftermarket suspension, i dont want to lower the car and i dont want adjustable control arms, if anything adjustable shocks,is this also a good way to go???
http://www.donttearmedown.com/
Old March 1st, 2007, 11:36 AM   #8
Stangzilla's Avatar
The Strange units I have are 5 way adjust. I like that better myself. they are easier to adjust where you want them with less settings.. IMO
Old March 2nd, 2007, 12:35 PM   #9
homebrewed's Avatar
'88 LX body '91 GT D/T
8.7 in the 1/8th
homebrewed is on a distinguished road
+1 on the Strange. The Strange setup will make you very happy.
Having the ability to control the damping force on your suspension is great for any vehicle. Even moreso if you use it in a competitive nature
Founder of the I don't like my shit centerd and want it back the way it was dammit! club
www.myspace.com/evoalliance
greatest band alive
Originally Posted by Tony_90fox View Post
I wish there was a :lickmynuts smiley, because i would use it now
:lickmynuts
Threads Similar to: Drag Suspension Setup?
best suspension setup? madhandles97 General Tech 1 October 27th, 2007 12:24 AM
suspension setup travis_afx 99-04 16 September 11th, 2007 03:05 PM
Best drag setup for 91 notch cams-shelbycobra07 General Tech 7 August 13th, 2007 10:13 AM
Suspension Setup Dawgs2099 99-04 7 May 30th, 2007 11:45 PM
suspension setup xzibit88 General Tech 9 April 5th, 2007 11:01 PM
