Come at me bro
'89 LX 'Vert
10's or bust... Literally.
PCV system question
About to button my motor back up.
Made the mistake of buying valve covers with a spot for a PCV valve on the driverside valvecover..... So it would be simple, and cost a hole $3 to run a hose from the upper intake to a pcv in the valve cover, and run my normal pcv to the back of the intake. running 2 pcv valves. now would this make the motor suck up more oil into the intake? or any odd effects? or would the motor's PCV system work better since it will live in higher RPM's and a "higher performance" area then the stock PCV system was designed for? OR I could just plug the valve cover up, and run the OEM pcv to the back of the intake and thats it. what's your thoughts? thanks in advance.
1989 Fox H/C/I 302 & 2013 GT 5.0 Stock 370rwhp 352rwtrq ![]() www.youtube.com/Xarmy187
![]() Please support my YouTube channel! My videos don't disappoint! 2.2 MILLION views (and counting) can't be wrong!! |
Ice Cream Truck Driver
its honestly ur choice, u don want some sort of evac u could just put a twist cap on ur valve cover, u could tee off ur pcv line and run 2 pcvs. or u could go bad ass and pull ur crank case gases through your exhaust, which is alot more work, but efficent and the definition of joe kick ass, or u could just put a breather on it on, either way you at least 1 vent on ur car... i personally am running 2 pcv valves w/ 3/8 hose to a tee to my carb. the valve covers i got came w/ nice chrome twist caps w/ a pcv hole in em.
![]() MM+Cleavage Club Founder/Member #1 *MM's Thread of the YEAR*
Come at me bro
'89 LX 'Vert
hmm, ive always heard running a breather will create a vacuum leak?
Im just not sure how the system works, I know it pulls in a little oil, and the motor eats it up, i just dont want this thing sucking up a ton of oil or causing other random issues.
#4 | |
Tester
Rusty |
#5 | |
...on secont thought dont do that, i might like it, then itll be weird and not funny.... ![]() anyhoo, runnin a breather on ur valve covers wont give u vac leak. u only have vacuum through the intake manifold, and any hoses connected to ur vacuum. if ur eatin sum earl" change over 2 breathers, or use some baffled valve covers that keep oil from gettin sucked up....
The Big Spoon
88 5.0 5 Speed Notch <><
never fast enough
my pcv sucks up carbon and makes my throttle plate stick. I am using a little trick I learned from my pops that involves putting one of those see through fram fuel filters in line. Problem solved and no more stickeyness.
Your PCV will be pulling unmetered air into the intake through the breather (vac leak). If you have EFI, run either a PCV or a breather, not both.
The PCV air enters the intake on the engine side of the throttle plate. Are you sure your source for build up is not the line from the valve cover to the throttle body which is before the throttle plate?
#9 | |
Come at me bro
'89 LX 'Vert
any thought if two PCV's will help or hurt?
#10 | |
true, didnt think of that, although i run a carb... ![]() 1's fine, 2's better, although 1 is sufficent (did spell that right?) pcv dont give u horses, as long as u run 1 ull be fine. also, im not 2 familliar w/ the fuel injected intakes, isnt there like a filter screen that keep oil from gettin in the intake????
#11 | |
1991 Mustang LX 5.0
FastStang's Ongoing projects thread Click here! |
Threads Similar to: PCV system question
| cobra electric vaccum pump to ditch PCV system | wraitherx | 4V / SVT | 24 | December 14th, 2011 10:19 PM |
| PCV hose question... | The AdMan | 2005 - 2010 | 2 | January 14th, 2011 04:48 PM |
| 1996 PCV question | nHuman | 96-98 | 5 | February 8th, 2009 09:49 PM |
| PCV valve question | MWWarlord | V6 Mustangs | 15 | April 6th, 2008 12:56 AM |
| 66 Mustang 200ci i6 - Change Breather to PCV type system | cgstarry | Classic Mustangs | 3 | September 2nd, 2007 03:00 PM |
