bad O2 sensor?
LinkBack (1) Thread Tools
Old February 10th, 2010, 01:53 AM   1 links from elsewhere to this Post. Click to view. #1
1988 Mustang 5.0 LX
12.48@118.27
ddarkslayer is on a distinguished road
bad O2 sensor?
so the threads I've made the past couple of weeks of my motor running rich and Idle surges. The idle surges where because I forgot to plug the MAF back in when I changed the sample tube and I went under my car today to inspect the 02 sensors I pulled them out and noticed that there was nothing but carbon deposit built up in volume on both of them and I shake the driverside o2 sensor and I can hear this rattling. So I'm assuming its gone bad But I'm not for sure tho. I used the kitchen stove to warm up the sensor while I used a multimeter to see if there where any changes in voltage or resistants. it didn't show any voltage and the resistance kept jumping all over the place. so I'm not sure if I've done it right. What do you guys think?
Old February 10th, 2010, 01:55 AM   #2
aka Nature boy
sickfox's Avatar
blk 89/red 91 XJ Limited
I like turtles
sickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant futuresickfox has a brilliant future
How does it run from a cold start? Start right up and run fine or idle ruff/like shit tills its warm then get better?
Black Stang Crew Founder #-1
MM+Cleavage Club #15
www.xjor.org
I would drag my dick through a mile of broken glass just to hear her fart through a walkie talkie
Old February 10th, 2010, 02:28 AM   #3
1988 Mustang 5.0 LX
12.48@118.27
when I start it up it runs fine for a couple of seconds and then the check engine light comes on. and the rpm drops
Old February 10th, 2010, 02:38 AM   #4
aka Nature boy
sickfox's Avatar
I like turtles
Did you pull codes? But id say its the o2's. I know my truck needs them and it wont idle cold with out me holding the gas a bit. Then it surges also. I dont knwo the symptoms of a stang with bad o2's cause I havent had to deal with them yet. Altho my fox does have idle surge problems.. Ill be changing out somethings this spring tho.
www.xjor.org
Old February 10th, 2010, 02:40 AM   #5
1988 Mustang 5.0 LX
12.48@118.27
its code 92 a rich code
Old February 10th, 2010, 02:42 AM   #6
aka Nature boy
sickfox's Avatar
I like turtles
Well if they are bad it sends the wrong signal, so it dont know how much fuel to give right?
www.xjor.org
Old February 10th, 2010, 02:47 AM   #7
1988 Mustang 5.0 LX
12.48@118.27
well this is my theory. I put stabilizer in the tank and ran half the amount of fuel that you normally have to run it with so I'm running a higher concentrate of fuel stabalizer so the stabalizer is cleaning up the carbon deposit all in the inside of the motor and contaminating the O2 sensors. thats just my theory but I don't know if that would make sense or not
Old February 10th, 2010, 02:48 AM   #8
aka Nature boy
sickfox's Avatar
I like turtles
Idk, Was it acting like this before you added the stable
www.xjor.org
Old February 10th, 2010, 02:52 AM   #9
1988 Mustang 5.0 LX
12.48@118.27
no it started acting like that when I installed the 255 fuel pump but the stablizer went in first.
Old February 10th, 2010, 02:53 AM   #10
aka Nature boy
sickfox's Avatar
I like turtles
Hrmm... Hope someone with better knowledge chimes in I guess. If it was me i would change the O2's
www.xjor.org
Old February 10th, 2010, 02:56 AM   #11
1988 Mustang 5.0 LX
12.48@118.27
haha yea thats what I'm going to do first thing tomorrow Cuz I got 164k on the motor and they are the original o2 sensors
Old February 10th, 2010, 02:58 AM   #12
aka Nature boy
sickfox's Avatar
I like turtles
yeah do that!!
www.xjor.org
Old February 11th, 2010, 12:46 AM   #13
1988 Mustang 5.0 LX
12.48@118.27
so I just changed the 02s and it still running rich. crap my next theory is the 24 Ibs. injectors It doesn't make sense because my car use to run fine with them in then when I changed the fuel pump to a 255 then it starts running rich
Old February 11th, 2010, 04:59 PM   #14
1988 Mustang 5.0 LX
12.48@118.27
now I just drove around the block and I have a slight exhaust leak and so when I floor it I get smoke building up in my interior I have a broken main harnest grommet to
Old February 11th, 2010, 05:40 PM   #15
aka Nature boy
sickfox's Avatar
I like turtles
How is your maf? Try cleaning it out maybe its getting a bad reading?
www.xjor.org
Old February 11th, 2010, 06:50 PM   #16
1988 Mustang 5.0 LX
12.48@118.27
I tested the resistance on every pin and it checked out okay I plugged it in and it doesn't surge anymore so the MAF is good dang I've ran out of Ideas
Old February 11th, 2010, 06:59 PM   #17
1988 Mustang 5.0 LX
12.48@118.27
What if I buy an ajustable fuel pressure regulator would that help or would that just be a bandaid to hide the real problem
Old February 11th, 2010, 08:31 PM   #18
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
Ehh I don't think so. If you read it via a wide band no matter how rich or lean you adjust an adjustable fpr its only making adjustments at wide open. The computer will always adjust the air fuels once you have made adjustments.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/152703-bad-o2-sensor.html
Mariska Hargitay - News, Links, Pictures and Videos This thread Refback February 10th, 2010 12:59 PM
Threads Similar to: bad O2 sensor?
slight miss or bad sensor? John's_stang 99-04 6 May 11th, 2009 12:49 PM
bad sensor? KevinJ99GT 99-04 8 September 3rd, 2008 11:48 PM
bad 02 sensor? chaosstangman 5.0 Mustangs 2 August 29th, 2008 12:48 AM
Bad O2 sensor? ltsmash1200 99-04 2 May 17th, 2007 01:09 PM
