what trans for 465 whp
Hi i decided im going to do a 5 spd swap instead of a built auto and im not sure what trans to go with really wanted to do a t56 but thats going to be about $4000 so i was wondering what other options i have and costs
if i go t56 i know it will actually be 6 spd
t-5. if you can shift. if not tko 600
1988 vert - still in progress 2004 F250 |
1991 Mustang LX 5.0
Astro T5, slash cut for street, straight cut (noisier) for track
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
1993 Mustang GT
unk right now as fast as i can push
go with what you got and see what happens, whats the worst you have to get a different tranny same boat with a delay..
As long as you have some common sense a T5-z is a great option.
The less sense you have you may want to upgrade to one of the following: Astro or G-force T5 TKO-500/600 (500 has a better 1st gear ratio) Tremec 3650 (promotion now makes a bellhousing adapter)
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
1988 Notchback
11.19 @ 122mph N/A
I would of just went with a built C4 and been done with it. But to each there own.
Depends on budget, but the TKO 500 and 600 transmissions seem to hold up pretty good. I have also heard good things from the Astro built T-5's
FluffyTheRhino: One time, the tramp I was fornicating with farted, and I felt it blow my balls backwards. 1988 Notch 347 C4 w/brake 3.90 gear 11.19 @ 122mph 60' 1.67 N/A Full Interiored pump gas car |
89 Mustang Hatchback
11.48 @ 119.2
I had the same dilemma. I decided to go with a built C-4 from Performance Automatic. I got their ProComp C4 (Built for 1000HP and guaranteed for LIFE) with a manual reverse valve body. I love it. Still have to shift every shift and have engine braking in second. My ET's are now extremely consistent. Your choice though
89 Mustang, 347, Probe forged innards, Edelbrock Vr. Jr Heads and intake, MSD spark, BBK long tubes, great Crane hydraulic roller rocker, 670 Holley, ProComp C4, 4.10 gears with 31 spline axles. |
#9 | |
Zip Your my Hero....
1988 Mustang LX
N/A
+1. The TKO is a great option because you can always add some ponies to it later as well. |
Atomized
I want to get my t56 in so bad. I heart t56's
spray and pray |
ok i decided to go with the t56 magnum transmission with all the goodies for the conversion.I went with a fadenza flywheel and a spec stage 3 clutch good for 700 hp and a custom shortened aluminum drive shaft and a custom made trans cross member.I didnt want to go with a built c4 cause it is more of a street car and didnt wnat to run out of gear with the engine rpms up when im cruising.
#12 | |
1988 Mustang Notch
it's a bad bitch..i promise
"didnt want to run out of gear with the engine rpms up when im cruising" ???? im clueless ??? C4's can't be driven on the street ? Well gee, I've got a C4 blower car with a measly 3:73 in it and I don't have no problems cruising the street or even hopping on the hwy... ?
'88 Notch ~ T-70 & Faceplated GForce! Tuned by [B][I][U]Kurgan Motorsports[/U][/I][/B] |
what i mean is, right now i have an aod in there and if i dont use the over drive and im in 3rd and im on the parkway going 70 im already up pretty high in the rpms so i thought with a c4 im gunna have the same thing since its only a 3 speed or am i wrong. i dont want to hear the drone of my exhaust if im going on a long cruise sorry if i you got the wrong idea never meant that it couldnt be used but just not for me. so just curious when your criusing at say 65 -75 what rpms r u at i was at like 4000 with the aod using just the 3 gears no overdrive and a 373 as well
1988 Notchback
11.19 @ 122mph N/A
Im around 3400-3500rpm around 65mph with 3.90 gears and 27" MT drag radials
#15 | |
Awesome Sauce
U.S. Army Retired Owner: Crankgoboom Racing James G. Bilkey - "You will never be the person you can be if pressure, tension, and discipline are taken out of your life." |
I wish i could help but the shop that did my engine build is also doing the conversion and ordering everything for me.Try googling it and you will prob find everything you need
#17 | |
1988 Notchback
11.19 @ 122mph N/A
Threads Similar to: what trans for 465 whp
| what kind of trans for 460 whp and what rear | 87superduperstang | 5.0 Mustangs | 13 | February 3rd, 2010 09:10 AM |
| 400-450 whp?? | 91 fox | 5.0 Mustangs | 32 | September 13th, 2009 10:26 AM |
| 426 whp in n/a 2v? | Smoothgrandmama | The Clubhouse | 9 | April 5th, 2009 11:35 PM |
| 300 whp n/a? | wishIhada5.0 | 99-04 | 22 | August 16th, 2008 08:15 AM |
