91 coupe
Engine rebuild
Cam & Rocker Lift Help!!!
Ok if i have a 518/518 lift cam an i use 1.6 0r 1.7 RR will that make the cam lift bigger? will i have to worry about pistion to valve issuse ? using keith black flat tops 2.02/1.60 relief cuts. heads are gt 40 with 2.02/1.60s . springs are good for 550 lift
07 Turbo Focus
12.93 @ 105mph
You could use the 1.7 rockers for a higher lift. I recommend that you always check piston to valve clearance. It's one area that you can't ignore, always check it when installing new valvetrain, even if it's basically stock. One thing to make sure of is the cam timing. Over time the cam can move out of time due to inbalance. The stock damper is weighted on the outside with a rubber seal on the inside. Over time the rubber seal can lose grip and make the cam go out of time slightly. I've seen quite a few 100k mile 302s that are having vibration issues and it's due to the timing being 3-4* out of spec. If going that much higher over stock, I would recommend getting an aftermarket damper that is weighted on the inside.
2007 Focus - 230/215, cams/head/manifold swap done, new #s soon ...going E85! 1985 Bronco - 351W & 4WD 1986 Mustang LX - 351W build in the works! David Michael Smith, 07/25/1956 - 12/08/2011 ...R.I.P dad! I miss you dearly! Last edited by RDY4WAR; February 14th, 2010 at 04:47 PM. |
1990 LX hatch
Odds are you'll need more spring. Allways measure for ptv clearance.
#4 | |
PeteAndersonRacing.com |
07 Turbo Focus
12.93 @ 105mph
an out of balance one does...
2007 Focus - 230/215, cams/head/manifold swap done, new #s soon ...going E85! 1985 Bronco - 351W & 4WD 1986 Mustang LX - 351W build in the works! David Michael Smith, 07/25/1956 - 12/08/2011 ...R.I.P dad! I miss you dearly! |
07 Turbo Focus
12.93 @ 105mph
The spin balancer is made of two parts, an outer and an inner part. There is a rubber seal in between the two. On the OEM balancer, it is weighted on the outside part. Over time, the rubber seal can crack and start pushing outward. When this happens, it causes the weight on the outer part to work against it and it actually slips on the inner part since it's not sealing off. I've personally seen it bad enough that the cam was actually off 4 degrees despite the balancer showing dead 0. I've really only seen this on heavy track run cars. Putting on an aftermarket balancer that is weighted on the inside part can prevent this issue.
1990 LX hatch
That's ignition timing, the cam sprocket is attached directly to the crank.
91 coupe
Engine rebuild
very true
Threads Similar to: Cam & Rocker Lift Help!!!
| Cam specs/lift | 88-gt-t-top | 5.0 Mustangs | 7 | April 4th, 2009 01:15 PM |
| New Fender Badges & No More Rocker Stripes | supermachone | The Clubhouse | 35 | December 15th, 2008 08:44 PM |
| Pics of bent push rod & broken rocker arm | supermachone | The Clubhouse | 5 | May 18th, 2008 01:02 AM |
| How to check lift on cam? | OldSchool | Classic Mustangs | 2 | February 5th, 2007 12:09 PM |
| Cam Lift | cali 5.0 | 5.0 Mustangs | 1 | November 7th, 2006 02:23 PM |
